path: root/board/hale
2015-09-11arm: Remove tt01 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-01-13mx31/mx35/mx51/mx53/mx6: add watchdogTroy Kisky
Use a common watchdog driver for all these cpus. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx31: Fix PDR0_CSI_PODFBenoît Thébaudeau
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0 register is actually composed of two bit-fields: one pre-divider and one post-divider. This patch fixes the CCM access macros and the code using them accordingly. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-02-27tt01: add video supportHelmut Raiger
The video setup for the Epson display is provided. Addtionally some extra info is displayed next to the Linux logo. Make get_cpu_rev() publicly available (added to sys_proto.h). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-12tt01: add MMC supportHelmut Raiger
board_mmc_init() initializes the pins of SDHC1 and turns on V_MMC1 of the PMIC. Config adds support for EXT2 and FAT. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2011-11-03mx31: Add board support for HALE TT-01Helmut Raiger
This adds basic board support for TT-01 based on the Bluetechnix i.MX31 SOM. Currently only NOR-Flash boot is implemented. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
