path: root/board/h2200/h2200.c
2015-09-07h2200: Fix build errorKishon Vijay Abraham I
Commit <8bfc288c3955> ("usb: gadget: ether: Perform board initialization from ethernet gadget driver") added board_usb_init and board_usb_cleanup in ethernet gadget driver. But h2200 board didn't have board_usb_init and board_usb_cleanup implementations. This introduced the following build errors +drivers/usb/gadget/built-in.o: In function `usb_eth_halt': +drivers/usb/gadget/ether.c:2498: undefined reference to `board_usb_cleanup' +drivers/usb/gadget/built-in.o: In function `usb_eth_init': +drivers/usb/gadget/ether.c:2316: undefined reference to `board_usb_init' Fix it here by adding empty board_usb_init and board_usb_cleanup functions in h2200.c. Fixes: <8bfc288c3955> ("usb: gadget: ether: Perform board initialization from ethernet gadget driver") Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2013-05-05h2200: Add board reset supportŁukasz Dałek
Use Samsung S3CA410X01 companion chip to reset PDA. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-12-17h2200: Add USB CDC ethernet supportLukasz Dalek
Add support for ethernet over USB which can be used for e.g. booting process. It works with tftp and dhcp clients code. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-10-16h2200: Add support for iPAQ h2200 palmtopŁukasz Dałek
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with Windows CE 4.2 operating system. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
