path: root/board/gth2
2007-11-19[MIPS] board/gth2/lowlevel_init.S: Fix a build warningShinya Kuribayashi
lowlevel_init.S: Assembler messages: lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local. Looking at codes, the `memtest' and `clearmem' are intentional mixed use of `global symbols' and `label' for debugging purpose. To make it build, just disable global-symbols-use for now. As a result `memtest' still remains as unused, but leave it be... Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-11-17[MIPS] gth2.c: Fix a warning on gth2 build.Shinya Kuribayashi
gth2.c: In function 'misc_init_r': gth2.c:434: warning: pointer targets in passing argument 2 of 'setenv' differ in signedness Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Remove duplicated .sdata sectionShinya Kuribayashi
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
