path: root/board/gth2/lowlevel_init.S
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2008-06-05[MIPS] Kill unused <version.h> inclusionsShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-19[MIPS] board/gth2/lowlevel_init.S: Fix a build warningShinya Kuribayashi
lowlevel_init.S: Assembler messages: lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local. Looking at codes, the `memtest' and `clearmem' are intentional mixed use of `global symbols' and `label' for debugging purpose. To make it build, just disable global-symbols-use for now. As a result `memtest' still remains as unused, but leave it be... Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
