Commit fe974716326c ("rockchip: rk3288: Allow setting up clocks in
U-Boot proper") fixes some clock issues when chainloading U-Boot on
rk3288 chromebooks. Part of that change is still available in veyron's
board_early_init_r() function. Since chain-loading U-Boot proper from
vendor firmware is possible on gru boards as well, do the same thing for
them too.
On rk3399, this needs to detect whether SPL was run via handoff, so
enable that and bloblist kconfigs it needs for chromebook_bob.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
This somehow ended up as an empty file. Fix it.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
This uclass is intended to provide a way to obtain information about a
U-Boot board. But the concept of a U-Boot 'board' is the whole system,
not just one circuit board, meaning that 'board' is something of a
misnomer for this uclass.
In addition, the name 'board' is a bit overused in U-Boot and we want to
use the same uclass to provide SMBIOS information.
The obvious name is 'system' but that is so vague as to be meaningless.
Use 'sysinfo' instead, since this uclass is aimed at providing information
on the system.
Rename everything accordingly.
Note: Due to the patch delta caused by the symbol renames, this patch
shows some renamed files as being deleted in one place and created in
another.
Add files describing the various audio configurations supported on coral.
These are passed to Linux in the ACPI tables.
This device has a large set of ACPI tables. Bring these in from coreboot
so that full functionality is available (apart from SMI).
This value is incorrect and causes problems booting Linux. Fix it.
Introduce USE_EARLY_BOARD_INIT option and select it by the actual users.
Cc: George McCollister <george.mccollister@gmail.com>
Reviewed-by: Aiden Park <aiden.park@intel.com>
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Current codes assume the OPTEE address is at the end of first DRAM bank.
Adjust the process to allow OPTEE in the middle of first bank.
When OPTEE memory is removed from first bank, it may split the first bank
to two banks, adjust the MMU table for the split case,
Since the default CONFIG_NR_DRAM_BANKS is 4, it is enough, just enlarge
i.MX8MP evk to default to avoid issue.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Tested-by: Silvano di Ninno <silvano.dininno@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Previously veyron_init() was called in board_init() context, which is
called after relocation. Moving it to veyron.c used board_early_init_f
which is called way earlier, and causes veyron_init to hang.
Using board_early_init_r instead fixes this.
Fixes: b678f2790c ("rockchip: rk3288: Move veyron_init() back to veyron.c")
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Add initial support for Google's Coral Dev Board based on i.MX8MQ.
https://coral.ai/products/dev-board
The Phanbell naming has been used here to match the naming convention
used in Google's U-Boot source tree:
https://coral.googlesource.com/uboot-imx/
Co-developed-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Alifer Moraes <alifer.wsdm@gmail.com>
Tested-by: Marco Franchi <marcofrk@gmail.com>
At present devres.h is included in all files that include dm.h but few
make use of it. Also this pulls in linux/compat which adds several more
headers. Drop the automatic inclusion and require files to include devres
themselves. This provides a good indication of which files use devres.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Add support for coral which is a range of Apollo Lake-based Chromebook
released in 2017. This also includes reef released in 2016, since it is
based on the same SoC.
Use common board file for board_init() and board_late_init(),
for Rockchip SoCs have very similar process.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The veyron_init() should go to its board file veyron.c,
and the board_early_init_f() could be the right place.
The board_early_init_f() is only used by veyron board now,
move it into the board file veyron.c
Add a board_early_init_f() in board_init_f() and move the board
specific init code into its own board file.
Add a version of samus which supports booting from TPL to SPL and then
to U-Boot. This allows TPL to select from an A or B SPL to support
verified boot with field upgrade.
This adds a MAINTAINER entry for chromebook_speedy.
Without this, we get the following warnings from the maintainers
check:
WARNING: no status info for 'chromebook_minnie'
WARNING: no maintainers for 'chromebook_minnie'
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Bob is a 10-inch chromebook produced by Asus. It has two USB 3.0 type-C
ports, 4GB of SDRAM, WiFi and a 1280x800 display. It uses its USB ports
for both power and external display. It includes a Chrome OS EC
(Cortex-M3) to provide access to the keyboard and battery functions.
Support so far includes only:
- UART
- SDRAM
- MMC, SD card
- Cros EC (but not keyboard)
Not included:
- Keyboard
- Display
- Sound
- USB
- TPM
Bob is quite similar to Kevin, the Samsung Chromebook Plus, but support
for this is not provided in this series.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This adds support for the ASUS C201, a RK3288-based clamshell
device. The device tree comes from linus's linux tree at
3f16503b7d2274ac8cbab11163047ac0b4c66cfe. The SDRAM parameters
are for 4GB Samsung LPDDR3, decoded from coreboot's
src/mainboard/google/veyron/sdram_inf/sdram-lpddr3-samsung-4GB.inc
Signed-off-by: Marty E. Plummer <hanetzer@startmail.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
'select n' selects a constant symbol, which is meaningless and has no
effect. Maybe this was meant to be a 'default n', though bool and
tristate symbols already implicitly default to n.
Discovered in Kconfiglib (https://github.com/ulfalizer/Kconfiglib),
which does more strict checking here:
kconfiglib.KconfigSyntaxError: board/google/Kconfig:34: Couldn't parse ' select n': expected nonconstant symbol
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Only a specific type of SPI flash exists on a board, having board
Kconfig to select the SPI flash seems to make more sense. Other
flash types are not necessary except coreboot, which implies all
available flash drivers there.
This is architecture-dependent early initialization hence should
be put in the platform Kconfig.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes
and should be not 'default y' for all x86 boards.
This is wrong at present, so genboardscfg.py gives the following warnings:
Fix it.
Add a new board config which uses 64-bit U-Boot. This is not fully
functional but is it a start. Missing features:
- SDRAM sizing
- Booting linux
- EFI support
- SCSI device init
(and others)
Set up the 64-bit U-Boot text base if building for that target.
This adds support for the Asus Chromebook Flip, an RK3288-based clamshell
device which can flip into 'tablet' mode. The device tree file comes from
Linux v4.8. The SDRAM parameters are for 4GB Samsung LPDDR3.
This adds support for the Asus Chromebit, and RK3288-based device designed
to plug directly into an HDMI monitor. The device tree file comes from
Linux v4.8.
Add a comment to indicate that we are not supporting the PWM regulator
yet.
At present we have a single rk3288-based Chromebook: chromebook_jerry. But
all such Chromebooks can use the same binary with only device-tree
differences. The family name is 'veyron', so rename the files accordingly.
Also update the device-tree filename since this currently differs from
Linux.
This adds basic support for chromebook_samus. This is the 2015 Pixel and
is based on an Intel broadwell platform.
Supported so far are:
- Serial
- SPI flash
- SDRAM init (with MRC cache)
- SATA
- Video (on the internal LCD panel)
- Keyboard
Various less-visible drivers are provided to make the above work (e.g. PCH,
power control and LPC).
The platform requires various binary blobs which are documented in the
README. The major missing feature is USB3 since the existing U-Boot support
does not work correctly with Intel XHCI controllers.
We don't need this anymore - we can use device tree and the new pinconfig
driver instead.
Instead of calling the northbridge and PCH init from bd82x6x_init_extra()
when the PCI bus is probed, call it from the respective drivers. Also drop
the Northbridge init as it has no effect. The registers it touches appear to
be read-only.
Do not set HAVE_INTEL_ME by default as for some cases Intel ME
firmware even does not reside on the same SPI flash as U-Boot.
These are currently dead codes. Until we have complete ACPI support,
we don't know if it works or not. Remove to avoid confusion.
This Kconfig option name indicates it has something to do with cpu
socket, however it is actually not the case. Remove it and move
options inside it to NORTHBRIDGE_INTEL_IVYBRIDGE.
There are some options which are never used, and also some options
which are selected by others but have never been a Kconfg option.
Clean these up.
This builds and displays an SPL message, but does not function beyond that.
MARK_GRAPHICS_MEM_WRCOMB is not referenced anywhere in the code,
hence remove it.
By making the board selections optional, every defconfig will include
the board selection when running savedefconfig so if a new board is
added to the top of the list of choices the former top's defconfig will
still be correct.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define
the text base address. Since it is deprecated, just remove it and use
CONFIG_SYS_TEXT_BASE directly.
Let arch/x86/Kconfig prompt board vendor first, then select
the board model under that vendor. This way arch/x86/Kconfig
only needs concern board vendor and leave the supported target
list to board/<vendor>/Kconfig.
Since driver model will probe the EC when it is first used, we do not
need to init it explicitly.
