path: root/board/gen860t
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
2002-09-18Initial revisionwdenk
