path: root/board/geekbuying
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11rockchip: correct the bank0 ram sizeKever Yang
The bank0 ram size should be the DRAM size minus reserved size, the DRAM size may be 1GB, 2GB, 4GB, we can not hard code it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added DECLARE_GLOBAL_DATA_PTR for RK3328, RK3368 and RK3399: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: use common sdram functionKever Yang
Replace the sdram_init() in board init and rockchip_sdram_size() in sdram driver for all the Rockchip SoCs which enable CONFIG_RAM. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Make dram_init() in rk3036-board.c conditional on CONFIG_RAM: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: rk3368: Add initial support for RK3368 based GeekBoxAndreas Färber
The GeekBox is a TV box from GeekBuying, based on an MXM3 module. The module can be used with base boards such as the GeekBox Landingship. This adds basic support to chain-load U-Boot from Rockchip's miniloader. Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
