path: root/board/ge
2019-04-13mx53ppd: bring dock out of reset at bootIan Ray
Configure GPIO BUFFERED_HOST_CONTROLLED_RESET_TO_DOCKING_CONNECTOR_N to bring the dock out of reset at boot. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: store version information in fdtIan Ray
Add board-specific FDT function to store U-Boot version in device tree. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: ppd: Enable CONFIG_DM_MMCIan Ray
Use MMC device model, and remove USDHC pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_SPI, CONFIG_DM_SPI_FLASHIan Ray
Use SPI flash device model, and remove SPI pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_GPIOIan Ray
Enable CONFIG_DM_GPIO as a pre-requisite for enabling CONFIG_DM_SPI. Add explicit gpio_requests. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_MMCIan Ray
2019-01-01imx: mx53ppd: fix build errorPeng Fan
board/ge/mx53ppd/mx53ppd.c: In function 'board_late_init': board/ge/mx53ppd/mx53ppd.c:359:23: error: passing argument 2 of 'read_vpd' from incompatible pointer type [-Werror=incompatible-pointer-types] res = read_vpd(&vpd, vpd_callback); ^~~~~~~~~~~~ In file included from board/ge/mx53ppd/mx53ppd.c:37:0: board/ge/mx53ppd/../../ge/common/vpd_reader.h:19:5: note: expected 'int (*)(struct vpd_cache *, u8, u8, u8, size_t, const u8 *) {aka int (*)(struct vpd_cache *, unsigned char, unsigned char, unsigned char, unsigned int, const unsigned char *)}' but argument is of type 'int (*)(void *, u8, u8, u8, size_t, const u8 *) {aka int (*)(void *, unsigned char, unsigned char, unsigned char, unsigned int, const unsigned char *)}' int read_vpd(struct vpd_cache *cache, ^~~~~~~~ cc1: all warnings being treated as errors Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de>
2019-01-01board: ge: Move VPD reading to the vpd_readerDenis Zalevskiy
Merge functionality duplicated in bx50v3 and mx53ppd: the logic is the same except that process_vpd is called at different phases. Also read_vpd could end up in error, so there is no VPD data in this case - it shouldn't be processed. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-12-17board: ge: Move VPD EEPROM configuration to the defconfigDenis Zalevskiy
Use standard configuration logic to define EEPROM constants. Names are based on VPD_EEPROM_ prefix because EEPROM_ is already used by i2c_eeprom driver. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-12-17board: ge: Remove EEPROM bus param from read_vpd()Denis Zalevskiy
The bus is statically defined, so remove redundant parameters from read_vpd() for PPD and Bx50v3. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: fix initialization of i2c bus0Dan Cimpoca
I2C bus 0 was not initialized correctly. There is an offset between i2c index and the structure number of pad info. So i2c bus 0 can be in an inconsistent state. This problem become visible on B{4,6}50v3 with the CPUC HW watchdog enabled. Sometimes when the CPUC HW watchdog interrupted the boot process, U-Boot was not able to read VPD from I2C/EEPROM and the system failed to boot up again, because a device connected to that bus was stuck in data transfer state (from previous boot attempt) and there was no method to recover (struct mxc_i2c_bus::idle_bus_fn was not set) courtesy of incorrect initialization. Signed-off-by: Dan Cimpoca <dan.I.cimpoca@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: b{4,6}50v3 modelineIan Ray
The b{4,6}50v3 kernel framebuffer console requires a modeline otherwise the LVDS panel shows garbage. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: correct LDB clockIan Ray
Use Video PLL to provide 65MHz for all displays. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: Change maintainerFabien Lahoudere
While using ./scripts/get_maintainer.pl I detect that the Maintainer name and address for bx50v3 boards are not valid. The new maintainer for GE bx50v3 products must be Ian Ray. Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-06-27imx: bx50v3: fix MaintainersStefano Babic
This fixes the warnings: WARNING: no status info for 'ge_bx50v3' WARNING: no maintainers for 'ge_bx50v3 Signed-off-by: Stefano Babic <sbabic@denx.de>
2018-05-17board: ge: bx50v3: remove redundant targetsIan Ray
This replaces TARGET_GE_B{4,6,8}50V3 with common TARGET_GE_BX50V3. The boards are identified automatically at runtime. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: configure video arguments using VPDIan Ray
Configure video arguments at run-time instead of at compile-time. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: use VPD instead of compile-time checksIan Ray
B{46}50v3s have an internal LCD that needs to be configured, in comparison with B850v3 which has only external displays. Use VPD instead of `CONFIG_TARGET_GE_B{4,6,8}50V3' compile-time checks to correct initialize video based on the monitor type. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: detect the monitor type by reading VPD earlierNandor Han
Move the VPD reading earlier in order to establish the monitor type as soon as possible. The configuration of the specific environment variables needs to be done later after the environment is configured. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: fix display support for b{46}50v3Ian Ray
Enable Video PLL to fix non-working display support for Bx50v3 internal displays. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: unify two switch statementsNandor Han
Simplify process_vpd() by unifying the switch statements handling product specific configurations. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: rename detect_baseboard functionIan Ray
The detect_baseboard() function actually determines whether there is an internal LCD panel or not. Rename for clarity. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15board: ge: bx50v3: enable backlight on demandIan Ray
Enable display backlight only if a message needs to be displayed. The kernel re-initializes the backlight, which results in some unwanted artifacts. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-04board,ge,bx50v3 - rtc time validationNandor Han
Validate the time at startup: - in case rtc error add to kernel command line RTC_ERROR - clamp date to 1-Jan-2036 Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Support FIT and select configuration based on VPDIan Ray
Modify configuration to support FIT. Set variable `confidx' from VPD, in order to load the correct device tree. Modify/simplify U-Boot environment to support loading FIT image. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Enable hardware watchdogMartyn Welch
Enable the hardware watchdog on bx50v3 to cause it to reset in the event the board hangs. Configure GPIO_9 pin as WDOG1_B so that a watchdog timeout results in a full system reset. The watchdog is used and reconfigured by systemd approximately 1.7 seconds into boot. Adding a few seconds for U-Boot and a few more seconds as a safety margin. Note that the PCIe controller is _not_ put back into a safe state prior to board reset. This is a problem if board reset is implemented as CPU reset. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: program MAC address to I210Hannu Lounento
There are two I210s on the b850v3 and one on the b450v3 and b650v3. One is connected to Marvell 88e6240 which is already programmed. Follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order. The environment variables are removed after programming the hardware because the variables seem to influence MAC addresses also after U-Boot. Specifically the MAC address of FEC (MC interface) would be incorrectly set: 'ethaddr', which maps to the first I210 chip and is set to I210's default address read from the driver by eth_write_hwaddr in eth_legacy.c because the variable is undefined (not set even by bx50v3.c), would result in the eth0 interface's MAC address to be set to I210's default address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: move FEC MAC address programming to driverMartyn Welch
Instead of programming the hardware directly in the board implementation, follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. This avoids duplicating the implementation as it already exists in the driver (drivers/net/fec_mxc.c: fec_set_hwaddr). The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order, i.e. FEC always has the index 2. The FEC driver does *not* set the flag Set MAC Address on Transmit (bit set_eth0_mac_address used to do but this is unnecessary as the Linux networking stack fills in the MAC address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: Enable access to i2c bus 1 and 2Martyn Welch
The change in i2c configuration added to support access to the VPD has inadvertantly caused access to i2c buses 1 & 2 to be lost. This has resulted in the configuration for the PMIC to be attempted on the wrong bus and thus isn't taking effect. Add the required configuration to return access to buses 1 & 2. In order to ensure that any users of the bus numbering prior to addition in VPD patches work, add buses before configuration related to mux on bus 0 and tweak VPD bus usage to fit new numbering scheme. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2017-12-29board: ge: mx53ppd: Move check_time() to common locationMartyn Welch
We are going to be using check_time() on more than the mx53ppd, move this function to a common location. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
2017-11-20mx53: Add Board support for GE PPDPeter Senna Tschudin
Create board support for GE PPD, based on mx53loco. Use mx53ppd_defconfig make target to configure for this board. Signed-off-by: Peter Senna Tschudin <peter.senna@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2017-11-20board: ge: make VPD code commonMartyn Welch
The VPD data is used on a number of GE products. Move the parsing code to a common location so that we can share this code. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Acked-by: Stefano Babic <sbabic@denx.de>
2017-10-12imx: Include <input.h> header fileDiego Dorta
When building with W=1 errors like the one below is seen: board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning: no previous prototype for ‘overwrite_console’ [-Wmissing-prototypes] int overwrite_console(void) Fix the build warnings by including <input.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-20board: ge: bx50v3: set eth0 MAC addressIan Ray
Define i2c mux configuration. Add new vpd_reader which is used to read vital product data. Read VPD from EEPROM and set eth0 MAC address. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Jose Alarcon <jose.alarcon@ge.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-03-26board: ge: bx50v3: apply the proper register setting to fix the voltage peak ↵Yung-Ching LIN
issue Apply the proper setting for the reserved bits in SetDes Test and System Mode Control register to avoid the voltage peak issue while we do the IEEE PHY comformance test Signed-off-by: Ken Lin <yungching0725@gmail.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Ian Ray <ian.ray@ge.com>
2017-03-26board: ge: bx50v3: fix AR8033 reset timing issueYung-Ching LIN
Add the delay (10ms) to ensure the clock is stable and to meet the clock-to-reset(1ms) requirement recommended in the AR8033 datasheet Signed-off-by: Ken Lin <yungching0725@gmail.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Ian Ray <ian.ray@ge.com>
2016-11-29board: ge: bx50v3: add the PMIC configuration supportKen Lin
Change the PMIC bulk configuration from auto mode to sync mode to avoid voltage dropout issue seen in auto mode. Signed-off-by: Ken Lin <ken.lin@advantech.com.tw> Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-07-28bx50v3: Use imx_ddr_size() for calculating the DDR sizeFabio Estevam
imx_ddr_size() can be used to calculate the DDR size in runtime. By using this function we no longer need to define PHYS_SDRAM_SIZE. Cc: Martin Donnelly <martin.donnelly@ge.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-06-07board: ge: bx50v3: don't configure the backlight when there's no displayAndrew Shadura
Don't try to configure the backlight when CONFIG_VIDEO_IPUV3 isn't set. Signed-off-by: Andrew Shadura <andrew.shadura@collabora.co.uk>
2016-04-19board: ge: bx50v3: Fix to meet LVDS display power on timingAkshay Bhat
On a reset/reboot, the display power needs to be off for atleast 500ms before turning it back on. So add a delay to the boot process to meet the display timing requirement. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-19board: ge: bx50v3: Use pwm for display backlightAkshay Bhat
Setup the LCD backlight brightness control pin to use PWM Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-19board: ge: bx50v3: Setup LDB_DI_CLK sourceAkshay Bhat
To generate accurate pixel clocks required by the displays we need to set the ldb_di_clk source on bx50v3 to PLL3 and b850v3 to PLL5. Since PLL5 is disabled on reset, we need to enable PLL5. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-19board: ge: bx50v3: Split display setup functionAkshay Bhat
B450v3/B650v3 uses single channel LVDS and does not support HDMI. B850v3 uses dual channel LVDS and supports HDMI. Hence split the display setup into two different functions. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-19board: ge: bx50v3: Disable unused pinsJustin Waters
Certain pins are not used on the i.MX6, and should have a neutral pad configuration in order to reduce electrical interference on the board. This commit defines these pins with a default value rather than relying on the system defaults. Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-03-09arm: imx: Add support for GE Bx50v3 boardsAkshay Bhat
Add support for GE B450v3, B650v3 and B850v3 boards. The boards are based on Advantech BA16 module which has a i.MX6D processor. The boards support: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
