path: root/board/ge/mx53ppd/ppd_gpio.h
2020-02-09board: ge: mx53ppd: use DM for uartIan Ray
Drop PPD_UART_PAD_CTRL since it matches defaults. Enable DM serial and MXC uart. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: mx53ppd: enable DM_VIDEOIan Ray
Enable DM_VIDEO for mx53ppd. Enable DM_REGULATOR_FIXED and DM_PWM for the backlight. Remove unused MX53PPD_LCD_POWER. Remove old (incorrect) setup_iomux_lcd. Enable backlight via display enable handler. Use cls command to initiate display in HW agnostic manner. Modify `failbootcmd' to use lcdputs. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2019-04-13mx53ppd: bring dock out of reset at bootIan Ray
Configure GPIO BUFFERED_HOST_CONTROLLED_RESET_TO_DOCKING_CONNECTOR_N to bring the dock out of reset at boot. Signed-off-by: Ian Ray <ian.ray@ge.com>
2017-11-20mx53: Add Board support for GE PPDPeter Senna Tschudin
Create board support for GE PPD, based on mx53loco. Use mx53ppd_defconfig make target to configure for this board. Signed-off-by: Peter Senna Tschudin <peter.senna@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
