path: root/board/gdsys
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-19mpc83xx: Add gdsys hrcon boardDirk Eibach
The gdsys hrcon board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x GbE (optional) - Lattice ECP3 FPGA connected via eLBC and PCIe Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-19board: iocon: Fix uninitialized accessDirk Eibach
Wolfgang Denk found this issue using cppcheck: (error) Uninitialized variable: fpga_features Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-19board: iocon: Fix fpga index in print_fpga_info()Dirk Eibach
2014-11-19board: dlvision-10g: Compile fixDirk Eibach
2014-07-07board: iocon: Modify iocon hardware startupDirk Eibach
To avoid peer "ChReceivePathStatus"-messages on iocon startup, initialize PHYs as soon as possible. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Enable scrambling on DP501Dirk Eibach
For proper displayport performance, scrambling has to be enabled, but is turned off on DP501 by default. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Make gdsys osd hardware detection more robustDirk Eibach
2014-07-07board: gdsys: Configure bridge on DP501 to support DDC onlyDirk Eibach
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: iocon: Support DisplayPort hardwareDirk Eibach
There is a new iocon hardware flavor, supporting DisplayPort finally. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: controlcenterd: Use new API for setting i2c busDirk Eibach
2014-07-07board: gdsys: Adapt sdhc_boot.c to mmc_get_env_addr API changeDirk Eibach
2014-07-07board: controlcenterd: Fix pci accessDirk Eibach
readl was called with values instead of pointers to these values. Why this ever did work is a mystery... Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19Fix bug in io64 target (introduced by commit aba27ac)Vasili Galka
From comparison of current logic and the logic that was prior to commit aba27ac, we see that first parameter of FPGA_GET_REG() shall be the FPGA index and not channel number. The re-factoring in commit aba27ac accidentally changed that. Cc: Stefan Roese <sr@denx.de> Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-11Check run_command() return code properlyThomas Betker
run_command() returns 0 for success, 1 for failure. Fix places which assume that failure is indicated by a negative return code. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-19powerpc/ppc4xx: Do full iocon PHY initialization in softwareDirk Eibach
Up to this point some PHY initialization was done from the FPGA and some from u-boot. From now all initialization is done from u-boot. To keep this maintainable a PHY setup machine was implemented that can execute commands from initialization arrays. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-08-19powerpc/ppc4xx: Add support for iocon-2Dirk Eibach
Add a new iocon flavor with a second communiction port per channel. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-08-19powerpc/ppc4xx: Add support for iocon fiberDirk Eibach
Add a new iocon flavor with fiber instead of copper connectivity. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-26powerpc/ppc4xx: Convert new gdsys files to SPDX license tagsTom Rini
2013-07-25powerpc/ppc4xx: Consider gdsys FPGA OSD sizeDirk Eibach
OSD size was constant 32x16 characters. Now the size is set as announced by the FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Support gdsys multichannel iocon hardwareDirk Eibach
2013-07-25powerpc/ppc4xx: Add gdsys mclink interfaceDirk Eibach
mclink is a serial interface for communication between gdsys FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Use generic accessor functions for gdsys FPGADirk Eibach
A set of accessor functions was added to be able to access not only memory mapped FPGA in a generic way. Thanks to Wolfgang Denk for getting this sorted properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-02-04ppc: Move fpga_state to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-04-30powerpc/ppc4xx: Remove typedefs for gdsys FPGADirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20Dirk Eibach
In hardware revision 1.20 one more fan controller is added to dlvision-10g. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changesDirk Eibach
Print fpga info at last_stage_init on gdsys 405ep boards. Use dtt_init() to startup fans. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-01-09ppc4xx: Setup HICB on Io64Dirk Eibach
The FPGA High-Speed Interconnect Bus (HICB) is now setup by u-boot. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-01ppc4xx: Add Io64 board supportDirk Eibach
Board support for the Guntermann & Drunck Io64. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-16dlvision-10g.c: Fix GCC 4.6 build warningsStefan Roese
Fix: dlvision-10g.c: In function 'print_fpga_info': dlvision-10g.c:90:11: warning: variable 'feature_compression' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-21ppc4xx: Set DLVision 10G osd position to linux defaultsDirk Eibach
2011-04-21ppc4xx: Adapt DLVision 10G to new FPGA firmwareDirk Eibach
2011-04-21ppc4xx: Improve video board detectionDirk Eibach
2011-04-21ppc4xx: Improve DLVision-10G PLL setupDirk Eibach
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
