[trini: Fixup common/cmd_io.c]
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
A large number of boards incorrectly used getenv() in their board init
code running before relocation. In some cases this caused U-Boot to
hang when certain environment variables grew too long.
Fix the code to use getenv_r().
Cc: Stefan Roese <sr@denx.de>
Cc: The LEOX team <team@leox.org>
Cc: Michael Schwingen <michael@schwingen.org>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Werner Pfister <Pfister_Werner@intercontrol.de>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Peter De Schrijver <p2@mind.be>
Cc: John Zhan <zhanz@sinovee.com>
Cc: Rishi Bhattacharya <rishi@ti.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
All these linker scripts can be removed since the new common ppc4xx
linker script should be able to handle all of those boards.
Please test and report problems. Thanks.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
The latest PPC4xx register cleanup patch missed the UIC defines.
This patch now changes lower case UIC defines to upper case.
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
Board support for the Guntermann & Drunck DL-Vision.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
