path: root/board/gcplus/u-boot.lds
2004-03-14* Patches by Travis Sawyer, 12 Mar 2004:wdenk
- Fix Gigabit Ethernet support for 440GX - Add Gigabit Ethernet Support to MII PHY utilities * Patch by Brad Kemp, 12 Mar 2004: Fixes for drivers/cfi_flash.c: - Better support for x8/x16 implementations - Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE - Added defines for AMD command and address constants * Patch by Leon Kukovec, 12 Mar 2004: Fix get_dentfromdir() to correctly handle deleted dentries * Patch by George G. Davis, 11 Mar 2004: Remove hard coded network settings in TI OMAP1610 H2 default board config * Patch by George G. Davis, 11 Mar 2004: add support for ADS GraphicsClient+ board.
