path: root/board/gateworks
2019-03-13imx: ventana: added support for 16bit 8Gb density (1GiB) DRAMTim Harvey
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-03-13imx: ventana: hexdump invalid EEPROM dataTim Harvey
2019-02-15imx: ventana: fix usage of dt paths with leading 0s (Linux 4.15+)Tim Harvey
device-tree paths should never be used that reference node addresses making an assumption about leading zeros. They should not be there per the device-tree specification however they have been there until Linux 4.15 when they were removed via kernel commit 8dccafaa281aa1d240a58bbcdff338aec114a021. This fixes various issues which will occur when using Linux 4.15+ that are being fixed up on a per model per PCB revision basis such as: - enabling MMC UHS-I on board revisions that support it - enabling PWM based on hwconfig - fixing PCIe reset on GW552x - removing cpu external watchdog reset on boards that do not support it - populate PCI dt nodes based on PCI scan in order to fix GW16082 interrupt mapping and inject MAC address for PCI based GbE Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: gw5904/gw5909: disable RS485Tim Harvey
The GW5904/GW5909 have a SP33E multi-protocol serial transceiver which we want to configure to RS232 by default (by de-asserting RS485_EN) Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: add support for GW5901/GW5902Tim Harvey
2019-02-15imx: ventana: add support for GW5909Tim Harvey
The GW5909 is a small single board computer based on the i.MX6DL SoC with the same peripheral set as the GW5904 but with half the DRAM loaded and an additional RS232 transceiver off UART2. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: add support for GW5908Tim Harvey
The GW5908 is a small single board computer based on the i.MX6DL SoC with the same peripheral set as the GW530x but with 1GiB density DRAM (64bit 512MiB). Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: add support for GW5907Tim Harvey
The GW5907 is a small single board computer based on the i.MX6DL SoC with the following peripheral set: - DDR3 memory (512MB default) - 1x GigE (i.MX6 FEC) - Gateworks System Controller Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: add support for GW5906Tim Harvey
The GW5906 is a GW552x with mechanical and power supply connector differences. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: add i2c detect for all LVDS displaysTim Harvey
2019-02-15imx: ventana: skip nand init for nandless boardsTim Harvey
2019-02-15imx: ventana: add support for Z101WX01 LVDS displayTim Harvey
2019-02-15imx: ventana: add support for GW5905Tim Harvey
The GW5905 is single-board tablet computer based on the i.MX6 SoC with the following peripheral set: - eMMC flash (boot device) - microSD expansion - LVDS display connector for off-board 3D+1C with PWM backlight and I2C based touch controller - MIPI camera connector supporting the TRULY CM8487-B500SA-E (OV5640) - ublox EMMY-W1 WiFi/Bluetooth/NFC module (SDIO/UART) - ublox ZOE-M8Q GPS - LSM9DS1 9-DOF IMU - 1x 1-lane miniPCIe socket with USB 2.0 - Gateworks System Controller - Audio jack with TLV320AIC Audio Codec, Speaker AMP and TSA227E Headphone detect - MAX8607 3-mode LED camera flash - DECT ULE module - FUSB302 USB-C PD and ISL9238 Battery charger Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: remove setup of I2C3 from SPLTim Harvey
Do not setup I2C3 in the SPL for Ventana as some devices on that bus (aic3x codecs) can hang the bus causing i2c_setup to spin endlessly until they are put into reset. Removing the setup of I2C3 from the SPL allows the board-specific GPIO to be configured to take care of putting codecs in reset prior to U-Boot setting up I2C3. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: do not iomux UART1Tim Harvey
The only UART that is garunteed on Ventana boards is UART2 (serial-console). Remove UART1 pinmux as that it is not consistent across all Ventana boards and U-Boot doesn't need it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2019-02-15imx: ventana: mv88e61xx change LED configurationTim Harvey
2018-07-25board: constify struct node_info arrayMasahiro Yamada
Add 'const' (also 'static' in some places) to struct node_info arrays to save memory footprint. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-12imx: ventana: Rework CONFIG_CMD_GSC code to not be included in SPLTom Rini
The command can only be used from full U-Boot, so do not build it into SPL. Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-12imx: ventana: Rework CONFIG_CMD_EECONFIG code to not be included in SPLTom Rini
2017-09-18imx6: drop duplicated bss memset and board_init_r() callAnatolij Gustschin
bss section is cleared in crt0.S. board_init_r() is also entered from crt0 code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <lukma@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop env_relocate_spec() in favour of env_load()Simon Glass
This is a strange name for a function that loads the environment. There is now only one implementation of this function, so use the new env_load() function directly instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-06-05arm: Include asm/setup.h explictlySimon Glass
Include this header where needed so we do not need to rely on common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_GSC to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_GSC Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EECONFIG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EECONFIG Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-18imx: ventana: update imx wdog external reset dt propertyTim Harvey
Early backports of the imx wdog external reset feature occured before the property was accepted upstream and used 'ext-reset-output' instead of 'fsl,ext-reset-output'. In order to support older kernels remove both properties. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2017-05-18imx: ventana: fix GW520x external watchdog dt updateTim Harvey
2017-05-12gw_ventana: Fix unused variable warningsTom Rini
The variable nfc_pads is only referenced when CONFIG_CMD_NAND is set, move the existing guard and drop a now redundant comment. The variable gwproto_gpio_pads is never referenced, remove it. Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30power: Drop CONFIG_I2C_PMICSimon Glass
This is only used by one board and should not be a CONFIG option. Instead it should use the driver model pmic framework. For now, just move the setting into the only board that uses it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-26imx: ventana: add new board configs to MAINTAINERSTim Harvey
2017-03-26imx: ventana: fix GW5903 VDD_ARM railTim Harvey
2017-03-20imx: ventana: add GW5903 supportTim Harvey
2017-03-20imx: ventana: add GW560x supportTim Harvey
2017-03-20imx: ventana: add GW5904 supportTim Harvey
2017-03-19imx: ventana: add EMMC configurationTim Harvey
Prepare for boards with EMMC instead of NAND flash Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2017-03-19imx: ventana: make SD3_VSELECT board specificTim Harvey
Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-03-19imx: ventana: make OTG VBUS power enable board specificTim Harvey
2017-03-19imx: ventana: fix hwconfigTim Harvey
2017-03-19imx: ventana: change name of rs232_en to indicate polarityTim Harvey
2017-03-19imx: ventana: move mmc_init to commonTim Harvey
2017-03-19imx: ventana: add additional DRAM configurationsTim Harvey
- 64bit 8gB density (4GiB) IMX6DQ - 64bit 4gB density (2GiB) IMX6SDL Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
