path: root/board/gateworks
2015-11-12gw_ventana: Remove empty reset_cpu()Fabio Estevam
There is really no need to provide an empty reset_cpu() implementation, so just remove it. Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tim Harvey <tharvey@gateworks.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric BĂ©nard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02imx: mx6: ddr init MMDC according to ddr_typePeng Fan
To i.MX6, DDR3 and LPDDR2 is supported, so rename function mx6_dram_cfg to mx6_ddr3_cfg and the original mx6_dram_cfg function only is a wrapper. The new reimplemented function mx6_dram_cfg only invokes mx6_ddr3_cfg when ddr_type is for DDR3. Later we can use ddr_type to initialize MMDC for LPDDR2. Initialize ddr_type for different boards which enable SPL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefan Roese <sr@denx.de>
2015-06-01imx: ventana: skip mtdparts fixup if no flashTim Harvey
This avoids an error message on NAND-less boards. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-06-01imx: ventana: hang if board model could not be determinedTim Harvey
If the EEPROM could not be read or is corrupt we always want to hang. Note that an error message will have been displayed by read_eeprom in this case. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-06-01imx: ventana: make fdt_file1 and fdt_file2 automatic and non-overridableTim Harvey
The fdt_file1 and fdt_file2 vars provide fallbacks for the fdt file loading script. There is no need to allow the user to override these as if they want to specify the fdt, they should do so in the first attempt which is the fdt_file var. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-06-01imx: ventana: make model env var automatic and non-overridableTim Harvey
We want to model env var to always reflect what was in the EEPROM. There is no point in allowing a user to override this. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-06-01imx: ventana: various board-specific GPIO config updatesTim Harvey
- Added iomux for CAN_STBY and RS484_TEN (GW52xx/GW53xx/GW54xx/GW551x) - Moved iomux of USBHUB_RST# out of board_ehci_hcd_init so that it is done regardless of USB being initialized in bootloader - Added usb_sel iomux/hwconfig for GW552x - Fixed mezzanine DIO for GW54xx - Fixed PANLEDR# for GW54xx - Fixed dio iomux/hwconfig for GW552x - Fixed dio iomux for GW551x - removed redundant #define Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-26imx: ventana: update README with Falcon mode documentationTim Harvey
2015-05-26imx: ventana: update README for micro-SD boot mediumTim Harvey
2015-05-21imx: ventana: config: enable Falcon modeTim Harvey
Falcon mode entails the SPL booting the OS directly instead of U-Boot. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: add pmic_setup to SPLTim Harvey
We need to do any PMIC setup in the SPL if we are to bypass U-Boot for falcon mode. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: use stack relocationTim Harvey
Certain features we desire require a larger stack than is available by using iRAM (most notably for us, env_mmc). Relocate the stack to DRAM so that we can use these features. Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-15imx: ventana: add GSC boot watchdog disable to SPLTim Harvey
If the SPL is to be used for Falcon mode then we need to make sure the SPL disable the GSC boot watchdog. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: add gpio setup to SPLTim Harvey
If the SPL is to be used for Falcon mode then we need to make sure it configures basic GPIO (iomux, padconf, and default output levels). Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: use common uart and i2c setup functions in SPLTim Harvey
Now that uart and i2c setup functions have been moved to common.c we can use these and remove code duplication. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: detect pmic using i2c probe instead of board modelTim Harvey
Avoid requiring board-model and probe pmic by its i2c address. This is in preparation for being able to call pmic_setup() from SPL and not need board type. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: move GSC boot watchdog disable function to gsc.cTim Harvey
Move the code that disables the GSC boot watchdog into gsc.c Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: split out common functions between SPL and ubootTim Harvey
Move shared functions used by both SPL and U-Boot to common.c: - setup_iomux_uart() and uart pad config - gpio pad config In the process also moved the following to common.c in preparation for calling it from the SPL: - split i2c setup into a shared function - move pmic init to setup_pmic() function to call directly from power_init_board() - split gpio setup into early (iomux and default pin config) and late (output configuration based on env) Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: default msata/pci mux to pci before PCI enumerationTim Harvey
PCI enumeration occurs early, before we fully configure our GPIO's. Make sure we steer the MSATA/PCI mux to PCI in board_init to ensure PCI is selected before enumeration. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: fix pcie reset for GW522xTim Harvey
The re-assignment of pcie_rst gpio for GW522x needs to occur earlier, before the PCI subsystem calls the toggle funciton. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: enable DM_SERIALTim Harvey
mxc_serial supports DM so lets use it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: register gpio's with gpio_requestTim Harvey
Prior to using a gpio a call to gpio_request() should be called to register it with the gpio subsystem. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: display SPL boot deviceTim Harvey
Display what device the SPL will fetch uboot.img from Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: fix boot to SDTim Harvey
This fixes a regression caused by e25fbe3fe531029dc7b100ea4c79dbc802e17fc2 (gw_ventana: Move the DCD settings to spl code) The clock gating must be setup prior to calling arch_cpu_init(). Without this booting to SD (directly via eFuse or via bmode) will hang. Cc: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-04-22imx: ventana: Update missing memory/calib handlingPushpal Sidhu
This commit combines catching missing memory and calibration data into one if() block. It further prints pertinent information in determining why the failure occurred. Signed-off-by: Pushpal Sidhu <psidhu@gateworks.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: Add new memory configurationPushpal Sidhu
Add memory configuration for an IMX6SDL + 1GB density DRAM. Signed-off-by: Pushpal Sidhu <psidhu@gateworks.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: set HDMI video in to yuv422bt656 for GW551x-ATim Harvey
The initial revision of the GW551x does not connect enough signals between the HDMI receiver and the IMX6 CSI for 16bit capture mode necessary for yuv422smp capture. Future revisions will, but for the initial rev force it to yuv422bt656 mode which requires an 8bit video data bus. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: use hdmiinfmt env var to override HDMI capture formatTim Harvey
The HDMI receiver used on the GW54xx and GW551x has a 16bit video data bus interconnect between it and the IMX6 CSI. This can be used in two different modes, each having advantages and disadvantages. Allow the hdmiinfmt env var to specify which format is desired (yuv422smp or yuv422bt656). Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add DT fixup for GW522x to change PCIE_RST# GPIOPushpal Sidhu
The GW522x is functionally the same as a GW52xx except for PCIE_RST# GPIO. Add a DT fixup to change this gpio upon bootup. Signed-off-by: Pushpal Sidhu <psidhu@gateworks.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add 'gsc wd' command for enabling and disabling GSC watchdogTim Harvey
This adds information about the Gateworks System Controller to the gsc command such as the firmware version, firmware CRC and status of the GSC watchdog (if its enabled and if its tripped). Additionally the 'gsc wd' command can be used to enable or disable the watchdog with the following usage: gsc wd enable [30|60] gsc wd disable Note that the GSC registers are battery-backed by the GSC coincell so once eanbled, they remain enabled across power-cycles or until either the GSC firmware has been updated or FLASH has been re-programmed by the Gateworks JTAG adapter. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: added device-tree display configuration for LVDS displaysTim Harvey
Configure kernel device-tree for display from env var. This is useful to specify the display present when the device-tree supports multiple non-detectable display configurations. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add support for DLC-700JMGT4 and DLC-800FIGT3 LCD displaysTim Harvey
Add LVDS support for two LVDS LCD displays: DLC-700JMGT4 - 7" 1024x600 DLC-800FIGT3 - 8" 1024x768 Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add DT fixup for GW54xx compatibility with older kernelsTim Harvey
Certain older kernels in use by some customers erroneously define a uart3 for GW54xx with a pinmux that conflicts with NAND. This will remove that node to avoid such conflicts. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: remove 128x16 calibration (share with 128x32)Tim Harvey
The calibration data for dual 2Gb density chips can be used for a single 2Gb density chip. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: updated 16bit DDR calibrationTim Harvey
Updated 16bit DDR calibration using values obtained from running the i.MX6 DDR Stress Test tool over a set of boards over full operationg temperature. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: added DT fixup for GW551x-A video inputTim Harvey
The GW551x-A revision does not have the CSI0_DATA_EN pin connected, therefore we need to make sure that signal is not muxed to the CSI_DATA_EN signal internally and do so by steering it to the unused GPIO5_IO20. We do this so that the kernel device-tree can properly define the signal for RevB and beyond boards that do have this hooked up properly and require it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: gsc: add new hwmon railsTim Harvey
Add a new voltage rail added in various -C revision PCB's. Additionally make VDD_CORE, VDD_SOC, and VDD_IO2 common as all Ventana boards have those. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add mem_mb dynamic env varTim Harvey
Certain OS bootscripts need to know how much memory a board has to adjust kernel parameters (namely Android). This allows those boards to determine mem size in MB. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: remove GSC hwmon voltage rail min/max testTim Harvey
The min/max of each depends not only on board but on CPU. Simplify by removing this rarely needed and difficult to maintain feature and just display the rails and their values. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: only pinmux FEC enet signals for boards using itTim Harvey
2015-04-22imx: ventana: add wdis config for GW5520Tim Harvey
2015-04-22imx: ventana: Add support for GW551xTim Harvey
The GW551x is a small form factor board based on the IMX6 SoC that includes: * up to 512MB DDR3 memory * up to 2GB NAND flash * 1x miniPCIe socket (with USB) * HDMI out (micro-HDMI) * HDMI in (micro-HDMI) * TTL level I/O (supported by GW16111 breakout board): * I2C * 2x UART * CAN * 2x DIO (GPIO/PWM) * USB OTG Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: disable IMX6 watchdogs on GW51xx RevA and RevBTim Harvey
A board level errata causes the IMX6 watchdog to be unstable on the GW51xx RevA and RevB boards which can cause the watchdog to trip extremely early (under 5seconds) under certain operating conditions. Disable the watchdog node in the device-tree to work around this issue. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: fix various sparse warningsTim Harvey
2015-04-22imx: ventana: set LTC3676 PMIC to appropriate values per datasheetTim Harvey
The IMX6 Datasheets specifies that when the IMX6 LDO is enabled (internal Anatop LDO's for VDD_ARM, VDD_SOC, and VDD_xPU) you need to provide 1350mV on VDD_ARM_IN and VDD_SOC_IN for IMX6Q@1GHz (Automotive) and 1275mV for IMX6DL@800MHz (Industrial). While we are still about 50mV shy on the IMX6Q operating at 1GHz we set it to the max we can and leave it up to the kernel to implement a regulator driver for the LTC3676 and put the LDO's in bypass mode which allows us to drop the voltages by 125mV respectively. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add support for 4Gb density mem devices with IMX6DLTim Harvey
2015-04-22imx: ventana: enable precharge power-down fast-exit modeTim Harvey
Enable fast-exit precharge mode necessary for some DDR3 devices being used on Ventana boards. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: add usb_pcisel hwconfig supportTim Harvey
The GW52xx has a MUX that can direct front-panel USB OTG to one of the miniPCIe sockets (for use with a cellular modem for example). Use hwconfig to steer this. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-22imx: ventana: remove unused GPIO configurationTim Harvey
