path: root/board/gardena
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop linux/stringify.h from common headerSimon Glass
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop flash.h from common headerSimon Glass
Move this uncommon header out of the common header. Fix up some style problems in flash.h while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-27mips: mtmips: enable SPL for all boardsWeijie Gao
This patch enables SPL for all mtmips boards. And also remove defconfig files which are intend to build ram bootable u-boot files. SPL_DM and OF_CONTROL are enabled for both boards. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-20smart-gateway-mt7688: Rework build time check for overwriting factory dataTom Rini
The board file has a build time check to ensure that we do not have the redundant environment overwriting the factory data. However, using the symbol CONFIG_ENV_SIZE_REDUND isn't strictly needed as that is always the same as CONFIG_ENV_SIZE. Use CONFIG_ENV_SIZE instead so that we can later drop CONFIG_ENV_SIZE_REDUND. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-09arm: at91: Add gardena-gateway-at91sam supportStefan Roese
The GARDENA smart Gateway boards are equipped with an Atmel / Microchip AT91SAM9G25 SoC and with 128 MiB of RAM and 256 MiB of NAND storage. This patch adds support for this board including SPL support. Therefore the AT91Boostrap is not needed on this platform any more. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-11-30mips: mt76xx: gardena-smart-gateway: Add factory data variable handlingStefan Roese
Some factory data is stored in the SPI NOR and needs to get extracted from there into U-Boot environment variables. This patch also includes a board-specific command "fd_write" to provide some dummy / default values for this factory-data in the SPI NOR flash. This should only be necessary for testing purposes though. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18mips: mt76xx: gardena-smart-gateway: Add board_late_init() to set LED def stateStefan Roese
This is needed to set the LEDs automatically to a default state, as configured in the dts. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18mips: mt76xx: gardena-smart-gateway: Configure GPIOs (digital vs analog)Stefan Roese
Configure digital vs analog GPIOs as needed on this board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-23mips: Add Gardena Smart-Gateway board supportStefan Roese
The Gardena Smart-Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional 128MiB SPI NAND storage. This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time. Signed-off-by: Stefan Roese <sr@denx.de> [fixed and regenerated defconfig files] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
