path: root/board/galaxy5200
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-25Add support for the galaxy5200Eric Millbrandt
Add support for the DEKA Research and Development galaxy5200 board The galaxy5200 is an Freescale mpc5200 based embedded industrial control board. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
