path: root/board/gaisler
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13sparc: Move cpu/leon[23] to arch/sparc/cpu/leon[23]Peter Tyser
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for GR-CPCI-AX2000 FPGA AX board. The FPGA is ↵Daniel Hellstrom
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Altera NIOS Development kit (STRATIX II ↵Daniel Hellstrom
Edition) with GRLIB template design. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Gaisler GRSIM/TSIM2 SPARC/LEON3 simulatorn. ↵Daniel Hellstrom
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
