path: root/board/gaisler/grsim/Kconfig
2014-11-04sparc: merge CONFIG_SYS_CPU and CONFIG_SYS_VENDOR definesMasahiro Yamada
For now, all the SPARC boards in U-Boot are provided by Gaisler. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
