Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
All in-tree boards that use this controller have CONFIG_NET_MULTI
added
Also:
- changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111
- cleaned up line lengths
- modified all boards that override weak function in this driver
- modified all eeprom standalone apps to work with new driver
- updated blackfin standalone EEPROM app after testing
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Edition) with GRLIB template design. See www.gaisler.com for information.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
