path: root/board/funkwerk/vovpn-gw
2007-07-09board/[f-l]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Consolidate mpc8260 linker scriptsGrant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-08-02Coding style cleanupWolfgang Denk
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
2005-05-30Patch by Juergen Selent, 17 May 2005:wdenk
Add support for Funkwerk VoVPN gateway module.
