path: root/board/freescale
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-07vf610twr: Tune DDR initialization settingsAnthony Felice
Removed settings in unsupported register fields. They didn’t do anything, and in most cases, were not documented in the reference manual. Changed register settings to comply with JEDEC required values. Changed timing parameters because they included full clock periods that were doing nothing. Signed-off-by: Anthony Felice <tony.felice@timesys.com> [rebased on v2014.10-rc2] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-09-30imx: mx6dlarm2: Add support for i.MX6Q/DL arm2 LPDDR2 boardsYe.Li
Update the ddr scripts for LPDDR2 and add two build configs for LPDDR2 arm2 board. Since the LPDDR2 arm2 board has different DDR size, use CONFIG_DDR_MB in defconfig to replace the PHYS_SDRAM_SIZE. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-30imx: mx6dlarm2: Add support for i.MX6DL arm2 DDR3 boardYe.Li
This patch adds the i.MX6DL arm2 board support. The i.MX6DL ARM2 shared the same board with i.MX6Q ARM2 board since the i.MX6DL is pin-pin compatible with i.MX6Q. The patch also support the DDR 32-BIT mode option. Please define CONFIG_DDR_32BIT in the board configure file to enable DDR 32-BIT mode.But due to the board design, it's 64bit DDR buswidth physically, so, if you CONFIG_DDR_32BIT, the DDR memory size will be half of it. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-09-25board/ls1021aqds: Add DDR4 supportYork Sun
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig for this variant to enable DDR4 support. RAW timing parameters are not added for DDR4. The board timing parameters are only tuned for single- rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM availability. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
2014-09-25ARMv8/ls2085a: Enable secondary coresYork Sun
Spin table is at the very beginning of boot code. Each core has an individual release address within the spin table, the ft_cpu_setup fn updates the "cpu-release-addr" property of each cpu node with the corresponding release address. Also fix CPU_RELEASE_ADDR to point to secondary_boot_func. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-09-25ARMv8/ls2085a_emu: Enable DP-DDR as standalone memory blockYork Sun
DP-DDR is used for DPAA, separated from main memory pool for general use. It has 32-bit bus width and use a standard DDR4 DIMM (64-bit). Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-24board/t1040qds: Add sgmii ports support in 0xA7 protocolPriyanka Jain
T1042QDS (T1042 is T1040 Personality without L2 switch) supports following sgmii interfaces with serdes protocol 0xA7 -SGMII-MAC3 on Lane B - slot 7 -SGMII-MAC5 on Lane H - slot 7 -SGMII2.5G-MAC1 on Lane C - slot 6 -SGMII2.5G-MAC2 on Lane D - slot 5 Add support of above sgmii interfaces Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2014-09-24powerpc/t104xrdb: Set DDR ODT to 75ohmPriyanka Jain
DDR-ODT require cfg_dram_type switch set properly as per DDR type. T1040RDB, T1042RDB boards have DDR3L type DDR, so cfg_dram_type should be set to OFF for DDR3L Update t104xrdb/README for switch setting Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24powerpc/t104xrdb: Add T1042RDB board supportvijay rai
T1042RDB is a Freescale reference board that hosts the T1042 SoC (and variants). The board is similar to T1040RDB, T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit(L2 Switch). T1042RDB is configured with serdes protocol 0x86 which can support following interfaces - 2 RGMII's on DTSEC4, DTSEC5 - 1 SGMII on DTSEC3 DTSEC1, DTSEC2 are not connected on board. This Patch - add T1042RDB support - updates README file for T1042RDB details and update commands for switching to alternate banks from vBank0 to vBank4 and vice versa This patch also does minor clean ups for fdt defines for T1042RDB and T1042RDB_PI board Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24powerpc/t104xrdb: Add Support of rcw for T1042RDB in u-bootvijay rai
This patch adds support of rcw for T1042RDB, it makes following changes : - Adds t1042_rcw.cfg file for serdes protocol 0x86 for T1042RDB - Renames t1042_pi_rcw.cfg file from t1042_rcw.cfg and also updates comments for valid serdes protocol which is 0x06 - Also updates CONFIG_SYS_FSL_PBL_RCW for T1042RDB Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24board/ls2085a: Update env_addr after NOR flash relocationPrabhakar Kushwaha
LS2085a has 2 regions in system memory map. Region1 is default map from where system boots. Once u-boot is moved to DDR, IFC is re-mapped to Region2. So, update gd->env_addr to reflect correct address. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24spi: mxc: fix sf probe when using mxc_spiNikita Kiryanov
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high across multiple transactions. This is set up by embedding the GPIO information in the CS value: cs = (cs | gpio << 8) This merge of cs and gpio data into one value breaks the sf probe command: if the use of gpio is required, invoking "sf probe <cs>" will not work, because the CS argument doesn't have the GPIO information in it. Instead, the user must use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must type "sf probe 15872". This is inconsistent with the description of the sf probe command, and forces the user to be aware of implementaiton details. Fix this by introducing a new board function: board_spi_cs_gpio(), which will accept a naked CS value, and provide the driver with the relevant GPIO, if one is necessary. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-22imx: ddr: Move mx6q_4x_mt41j128.cfg to mx6sabresd boardNitin Garg
Provide cgtqmx6eval board its own variant of ddr setup config file. Move board/freescale/imx/ddr/ mx6q_4x_mt41j128.cfg to board/freescale/mx6sabresd/ as this is was designed for the mx6sabresd board. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-09-22Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-09-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-09-17imx: Fix warning by building vf610twr_nandStefano Babic
commit d6d07a9b... arm: vf610: add NAND support for vf610twr generates the following warnings: WARNING: no status info for 'vf610twr_nand' WARNING: no maintainers for 'vf610twr_nand'WARNING: no status info for 'vf610twr_nand' This is due to the fact that vf610twr_nand_defconfig has no Maintainer. This patch proposed Alison as Maintainer and fix it. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Alison Wang <b18965@freescale.com> CC: Stefan Agner <stefan@agner.ch>
2014-09-16kconfig: armv8: move CONFIG_ARM64 to KconfigMasahiro Yamada
2014-09-16mx6qsabreauto: Staticize when possibleFabio Estevam
Turn all local symbols into static in order to make sparse happy. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-16mx6sxsabresd: Staticize i2c_pad_info1Fabio Estevam
i2c_pad_info1 is only used locally, so it can be made static. Fix the following sparse warning: board/freescale/mx6sxsabresd/mx6sxsabresd.c:160:22: warning: symbol 'i2c_pad_info1' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-16arm: vf610: add NAND support for vf610twrStefan Agner
This adds NAND support for the Vybrid tower system (TWR-VF65GS10) provided by the vf610_nfc driver. Full 16-Bit bus width is supported. Also an aditional config vf610twr_nand is introduced which gets the environment from NAND. However, booting U-Boot from NAND is not yet possible due to missing boot configuration block (BCB). Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-09-09mx6dlsabresd: Use its own DCD tableFabio Estevam
Currently mx6dlsabresd shares the same DCD settings with the nitrogen board. Provide a DCD configuration file specific to mx6dlsabresd with the settings recommended by the Freescale hardware team. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-08ls102xa: dcu: Add platform support for DCU on LS1021ATWR boardWang Huan
This patch adds the TWR_LCD_RGB card/HDMI options and the common configuration for DCU on LS1021ATWR board. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-09-08video: dcu: Add Sii9022A HDMI Transmitter supportWang Huan
On LS1021ATWR, Silicon's Sii9022A HDMI Transmitter is used. This patch adds the common setting for this chip. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-09-08arm: ls102xa: Add basic support for LS1021ATWR boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021ATWR board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-09-08arm: ls102xa: Add basic support for LS1021AQDS boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021AQDS board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-09-08net: Merge asm/fsl_enet.h into fsl_mdio.hClaudiu Manoil
fsl_enet.h defines the mapping of the usual MII management registers, which are included in the MDIO register block common to Freescale ethernet controllers. So it shouldn't depend on the CPU architecture but it should be actually part of the arch independent fsl_mdio.h. To remove the arch dependency, merge the content of asm/fsl_enet.h into fsl_mdio.h. Some files (like fm_eth.h) were simply including fsl_enet.h only for phy.h. These were updated to include phy.h instead. Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-20powerpc/t4qds: Move doc/README.t4240qds under board/freescale/t4qdsYork Sun
Board specific README file should be moved to board folder. Signed-off-by: York Sun <yorksun@freescale.com>
2014-08-20powerpc/T4240QDS/eth: some fix for XFIShaohui Xie
XFI is supported on T4QDS-XFI board, which removed slot3, and four LANEs of serdes2 are routed to a SFP+ cages, which to house fiber cable or direct attach cable(copper), the copper cable is used to emulate the 10GBASE-KR scenario. So, for XFI usage, there are two scenarios, one will use fiber cable, another will use copper cable. For fiber cable, there is NO PHY, while for copper cable, we need to use internal PHY which exist in Serdes to do auto-negotiation and link training, which implemented in kernel. We use hwconfig to define cable type for XFI, and fixup dtb based on the cable type. For copper cable, set below env in hwconfig: fsl_10gkr_copper:<10g_mac_name> the <10g_mac_name> can be fm1_10g1, fm1_10g2, fm2_10g1, fm2_10g2. The four <10g_mac_name>s do not have to be coexist in hwconfig. For XFI ports, if a given 10G port will use the copper cable for 10GBASE-KR, set the <10g_mac_name> of the port in hwconfig, otherwise, fiber cable will be assumed to be used for the port. For ex. if four XFI ports will both use copper cable, the hwconfig should contain: fsl_10gkr_copper:fm1_10g1,fm1_10g2,fm2_10g1,fm2_10g2 For fiber cable: 1. give PHY address to a XFI port, otherwise, the XFI ports will not be available in U-boot, there is no PHY physically for XFI when using fiber cable, this is just to make U-boot happy and we can use the XFI ports in U-boot. 2. fixup dtb to use fixed-link in case of fiber cable which has no PHY. Kernel requests that a MAC must have a PHY or fixed-link. When using XFI protocol, the MAC 9/10 on FM1 should init as 10G interface. Change serdes 2 protocol 56 to 55 which has same feature as 56 since 56 is not valid any longer. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-20mx6sxsabresd: Add Ethernet supportFabio Estevam
mx6sxsabresd board has 2 FEC ports, each one connected to a AR8031. Add support for one FEC port initially. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-20mx6sxsabresd: Convert to the new Kconfig styleFabio Estevam
mx6sxsabresd was not in the master branch when the conversion to the new Kconfig style happened, so convert it now so that it can build again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-20mx6sxsabresd: Update DDR initializationFabio Estevam
Use the latest DDR initialization values suggested by the FSL hardware team. While at it, add some comments for clarification. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-20mx31pdk: Change maintainerFabio Estevam
Currently I don't have access to a mx31pdk board. Magnus was the original maintainer of the board and accepted to take back this role. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-08-12powerpc/t104xrdb: support deep sleep in SPI/SD bootTang Yuantian
Add deep sleep support in SPI/SD boot. The destination address second stage uboot image is loaded to is changed because currently this address will be used by kernel which means we can't reserve it for resume. Entry point to kernel is still placed in second stage uboot. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-12powerpc/t1042RDB: Add Video - HDMI supportJason Jin
T1042 has internal display interface unit (DIU) for driving video. T1042RDB supports video mode via -LCD using TI enconder -HDMI type interface via HDMI encoder Chrontel, CH7301C encoder which is I2C programmable is used as HDMI connector on T1042RDB. This patch add support to -enable Video interface for T1042RDB -route qixis multiplexing to enable DIU-HDMI interface on board -program DIU pixel clock gerenartor for T1042 -program HDMI encoder via I2C on board This patch refer to the upstream diu patch (337b0c52b3296f371d04aef71a833e09110e0e6b) for T1040qds. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> [York Sun: resolve conflict and move changes to T104xRDB.h] Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-12fsl/diu: ch7301 encoder split off from t1040qds/diu.cWang Dongsheng
The ch7301 encoder not only used in t1040qds platform, so we split it for t1042rdb and LSx platform. Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-08-08pmic: pmic_pfuze100: Use a shorter name for PMIC nameFabio Estevam
It is redundant to use 'PFUZE100_PMIC' as the PMIC name because we already know it is a PMIC. Call it simply 'PFUZE100' instead. Cc: Tim Harvey <tharvey@gateworks.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-08Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-07-23mx6: Remove duplication of iomuxc structureFabio Estevam
There is no need to keep iomuxc_base_regs structure as it serves the exact same purpose of the iomuxc structure, which is to provide access to the GPR registers. The additional fields of iomuxc_base_regs are not used. Other advantage of 'iomuxc' is that it has a shorter name and the variable declarations can fit into a single line. So remove iomuxc_base_regs structure and use iomuxc instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-07-23mx6sxsabresd: Add PFUZE100 PMIC supportFabio Estevam
