This board is using floating point arithmetic to display
the SST39VF6401B flash size.
This actually generates errors with toolchains without
appropriate sw fp math functions available.
SST39VF6401B is the only flash for wich the size is displayed,
it's size is 8192KB and floating point calculation seems not
needed. Removing it.
Signed-off-by: Angelo Dureghello <angelo@kernel-space.org>
This is not a Kconfig option so changing to _CFG.
Signed-off-by: Angelo Durgehello <angelo@kernel-space.org>
This converts 4 usages of this option to the non-SPL form, since there is
no SPL_FEC_MXC defined in Kconfig
This converts 3 usages of this option to the non-SPL form, since there is
no SPL_TARGET_LX2160ARDB defined in Kconfig
no SPL_DWC_ETH_QOS defined in Kconfig
This is not used anymore. Drop the driver and Kconfig option.
This is not used. Drop the driver and Kconfig option.
This option is not defined anywhere. Drop it.
This option as well as CONFIG_TARGET_P1022DS and CONFIG_TARGET_P5020DS
are not defined anywhere. Drop them.
This option does not exist, so the Makefile rule does nothing. Drop it.
Drop this unused code.
https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq
make QSPI clock selection optional during SoC init for ls102xa
Fix regulator name for ls2_sfp
Update NXP RCW github repo
As explained in the text at the bottom of the page
https://source.codeaurora.org/external/qoriq/qoriq-components/rcw:
"QUIC repositories on this site will not receive any updates after
March 31, 2022, and will be deleted on March 31, 2023."
Point to the NXP RCW github repo instead.
Signed-off-by: Fabio Estevam <festevam@denx.de>
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
https://source.codeaurora.org/external/imx/imx-atf:
Point to the NXP ATF github repo instead.
Reviewed-by: Oliver Graute <oliver.graute@kococonnector.com>
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Select DM_SERIAL
Select DM_SERIAL
The prefix 0 has been dropped in dts, so correct in board file
After DM_SERIAL, and set pinctrl_uart1 as pre-reloc, no need initialize
iomux at board file.
The PCA9450 reset configuration can now be performed by the PCA9450 PMIC
driver itself, remove the hard-coded variant from board code and let the
PMIC driver perform this task using one-liner:
$ sed -i '/set WDOG_B_CFG to cold reset/,+2 d' $(git grep -l PCA9450_RESET_CTRL.*0xA1 board/)
Venice and i.MX93 EVK required slight manual fix up.
Reviewed-by: Fabio Estevam <festevam@denx.de>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
At this point, the remaining places where we have a symbol that is
defined as CONFIG_... are in fairly odd locations. While as much dead
code has been removed as possible, some of these locations are simply
less obvious at first. In other cases, this code is used, but was
defined in such a way as to have been missed by earlier checks. Perform
a rename of all such remaining symbols to be CFG_... rather than
CONFIG_...
At this point in the conversion there should be no need to have logic to
disable some symbol during the SPL build as all symbols should have an
SPL counterpart.
The main real changes done here are that we now must make proper use of
CONFIG_IS_ENABLED(DM_SERIAL) rather than many of the odd tricks we
developed prior to CONFIG_IS_ENABLED() being available.
Perform simple renames of:
CONFIG_VSC7385_IMAGE to CFG_VSC7385_IMAGE
CONFIG_VSC7385_IMAGE_SIZE to CFG_VSC7385_IMAGE_SIZE
Perform a simple rename of CONFIG_SLIC to CFG_SLIC
Perform a simple rename of CONFIG_RESET_VECTOR_ADDRESS to CFG_RESET_VECTOR_ADDRESS
Perform a simple rename of CONFIG_ICS307_REFCLK_HZ to CFG_ICS307_REFCLK_HZ
Perform a simple rename of CONFIG_FSL_SERDES2 to CFG_FSL_SERDES2
Perform a simple rename of CONFIG_FSL_SERDES1 to CFG_FSL_SERDES1
Perform a simple rename of CONFIG_FSL_PMIC_BUS to CFG_FSL_PMIC_BUS
Perform a simple rename of CONFIG_FEC_MXC_PHYADDR to CFG_FEC_MXC_PHYADDR
Perform a simple rename of CONFIG_FEC_ENET_DEV to CFG_FEC_ENET_DEV
At this point only the TARGET_T1042D4RDB variant of this is supported in
tree, so remove the remaining parts of the other platforms.
This is always defined to 16K, so we move this over to
include/fsl_validate.h to start with. Next, we rename this from CONFIG_
to FSL_. Coalesce the various comments around this definition to be in
fsl_validate.h as well to explain the usage.
No platforms enable this driver as there's no T1040D4RDB nor T1040RDB
support at this time. Remove.
CONFIG_FLASH_SPANSION_S29WS_N
CONFIG_FLASH_VERIFY
CONFIG_FSL_FM_10GEC_REGULAR_NOTATION
CONFIG_FSL_ISBC_KEY_EXT
CONFIG_FSL_TRUST_ARCH_v1
CONFIG_FSL_SDHC_V2_3
CONFIG_MAX_DSP_CPUS
CONFIG_MIU_2BIT_INTERLEAVED
CONFIG_SERIAL_BOOT
CONFIG_SPI_BOOTING
CONFIG_X86EMU_RAW_IO
As DM_ETH is required for all network drivers, it's now safe to remove
the non-DM_ETH support code. Doing this removes some board support code
which was also unused. Finally, this removes some CONFIG symbols that
otherwise needed to be migrated to Kconfig, but were unused in code now.
Only this platform sets this option, define it in the board Kconfig
file.
CONFIG_POWER_FSL
CONFIG_POWER_FSL_MC13892
CONFIG_POWER_HI6553
CONFIG_POWER_LTC3676
CONFIG_POWER_PFUZE100
CONFIG_POWER_PFUZE3000
CONFIG_POWER_SPI
CONFIG_POWER_TPS65090_EC
CONFIG_POWER_TPS65218
CONFIG_POWER_TPS65910
CONFIG_FSL_CADMUS
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
The rest of the unmigrated CONFIG symbols in the SRIO namespace do not
easily transition to Kconfig. In many cases they likely should come from
the device tree instead. Move these out of CONFIG namespace and in to
CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_PCI and
CONFIG_SYS_PCIE namespace do not easily transition to Kconfig. In many
cases they likely should come from the device tree instead. Move these
out of CONFIG namespace and in to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NUM
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NS16550
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NOR
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NAND
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
For 2022.01
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/14083
- Fix UART
- moved to binman (MX8 boards)
- Toradex: sync DTS with Linux
- Gateworks: fixes
- New boards : MSC SM2S iMX8MP
Migrate all of COFIG_SYS_FSL* to the CFG_SYS namespace.
Migrate all of COFIG_SYS_MPC* to the CFG_SYS namespace.
