Crossbar switches were wrongly programmed to
route the CPRI lanes to SFP as the connectivity table
was not correct.
Modified it correctly for SFPs connections.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
QSGMII card has different PHY address against previous SGMII card.
We check the type of card in slots and set correct PHY address to
avoid complainning "PHY reset timed out" during u-boot booting up.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
SW7[4] is the new bit which controls the mapping of eMMC vs SDHC.
Signed-off-by: York Sun <yorksun@freescale.com>
- Added SERDES2 PRTCLs = 0x98, 0x9E
- Default Phy Addresses for Teranetics PHY on XAUI card
The PHY addresses of Teranetics PHY on XAUI riser card are assigned
based on the slot it is in. Switches SW4[2:4] and SW6[2:4] on
AMC2PEX-2S On B4860QDS, AMC2PEX card decide the PHY addresses on slot1
and slot2
- Configure MDIO for 10Gig Mac
Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com>
Debug trace buffers are memory mapped in DCSR space beyond 4M.
Signed-off-by: Stephen George <stephen.george@freescale.com>
Provided a default RCW for P5040, then it can use PBL to build
ramboot image.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Use QIXIS measurement registers to obtain sysclk and ddr clock. This
allows using non-standard clock speeds, set by directly writing to
clock chip or store the values in qixis clock data eeprom.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
QIXIS includes frequency measurement functions for each major processor
clock input. After reset (and after clocks are stable), QIXIS measures
the clocks against a reference frequency and stores the results in
CLK_FREQ registers. A base register supplies a multiplier which allows
directly obtaining the measured value, without requiring knowledge of
the target system or QIXIS core frequency.
Added a default RCW(1_28_6_12) and PBI configure file for T4240, so it can use
PBL tool to produce the ramboot image.
Allow VDD voltage overriding with a command. This is an add-on feasture of
VID. To override VDD, use command vdd_override with the value of voltage
in mV, for example
vdd_override <voltage in mV, eg. 1050>
The above example will set the VDD to 1.050 volt. Any wrong value out of
range of 0.8188 to 1.2125 volt or invalid string is ignored.
In addition to the command, if overriding VDD is needed earlier in booting
process, save an variable and reboot:
setenv t4240qds_vdd_mv <voltage in mV>
saveenv
Print more detail information including core voltage, RCW source, switch
settings, etc. with bdinfo command.
CC: Wolfgang Denk <wd@denx.de>
CC: Tom Rini <trini@ti.com>
QSGMII card assumed to be used by default, but if SGMII card is used,
it will use different PHY address, but we don't know which card is used
until we access PHY on the card. So we check the card type slot by slot,
if we can read a PHY ID by reading a SGMII PHY address on a slot, then
the slot must have a SGMII card pluged, we mark all ports on that slot,
and fix dts to use the SGMII card PHY address when doing dts fixup
for the marked ports.
Only clear IRE bit in qixis brdcfg5 register and keep other bits
unchanged.
B4860QDS requires DDRC2 has 0 as base address and DDRC1 has higher address.
This is the requirement for DSP cores to run in 32-bit address space.
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card
PHY address is variable depends on different slot.
1, Implemented board_ft_fman_fixup_port() to fix port for kernel.
2, Implemented fdt_fixup_board_enet() to fix node status of different
slots and interfaces.
3, Adding detection of slot present for XGMII interface.
4, There is no PHY for XFI, so removed related phy address settings.
T4240 has voltage ID fuse. Read the fuse and configure the voltage
correctly. Core voltage has higher tolerance on over side than below.
Update the timing table to support more rank density, based on the theory
that similar density DIMMs have similar clock adjust and write level start
timing. Update the timing for 1600 and 1866 MT/s. Tested with Micron
MT18JSF1G72AZ-1G9E1 DIMMs, iDIMM M3CN-4GMJ3C0C-M92.
Reverse the bit sequence to set and display serdes clock frequency
correctly. The correct bit maps in BRDCFG2 are
0 1 2 3 4 5 6 7
S1RATE[1:0] S2RATE[1:0] S3RATE[1:0] S4RATE[1:0]
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Many boot image configuration files refer to the
appropriate documentation file, but these references
contain typos in the directory and file name. Fix
them. Also fix reference to doc/README.SPL file.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
When P1021RDB-PC reboot system, the board will hung at uboot DDR
configuration. For P1021RDB-PC DDR reset pin is multiplex with
QE, so uboot will reserve this pin for QE and skip DDR reset.
Other platforms without QE will do this reset. This patch adds
a slight code to reset DDR chip by QE CE_PB8 pin for NAND and
NOR FLASH boot. For booting from SPI FALSH and SD card, it
seems possible to use the rom on chip to write to the GPIO
pins before configuring the DDR.
Signed-off-by: Xu Jiucheng <B37781@freescale.com>
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
Change flexcan compatible string from "fsl,flexcan-v1.0"
to "fsl,p1010-flexcan" to match the device tree.
Resolve P1020 second USB controller multiplexing with eLBC
- mandatory to mention USB2 in hwconfig string to select it
over eLBC, otherwise USB2 node is removed
- works only for SPI and SD boot
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Zhicheng Fan <B32736@freescale.com>
Add the tlb entries based on the configuration of the SRIO interfaces.
Every SRIO interface has 256M space:
#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000
#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull
#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000
#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Add defines needed to access NAND, remove second flash bank that is
actually connected to NAND.
Add nand booting support for P1022DS with hardcoded DDR config using
SPL framework from 2011
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Jiang Yutang <b14898@freescale.com>
property
For linux 3.x, the size of each item in interrupt-map property is 9 not 7.
Don't use the static value and calculate the size with following cells:
PCI #address-cells, PCI #interrupt-cells,
PIC address, PIC #address-cells, PIC #interrupt-cells.
Signed-off-by: Bin Jiang <bin.jiang@windriver.com>
This patch add support for storing the environment redundant on
mmc devices. Substantially it re-uses the logic from the NAND implementation,
that means using an incremental counter for marking newer data.
Signed-off-by: Michael Heimpold <mhei@heimpold.de>
Commit 3ebd1cbc introduced compiler-generated __bss_start
and __bss_end__ and commit c23561e7 rewrote all __bss_end__
as __bss_end. Their merge caused silent and harmless but
potentially bug-inducing clashes between compiler- and linker-
generated __bss_end symbols.
Make __bss_end and __bss_start compiler-only, and create
__bss_base and __bss_limit for linker-only use.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Let all ARM linker scripts handle properly -ffunction-sections
and -fdata-sections. This will be useful for future changes in order to create
symbol-specific sections in common .S files.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB
pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this
board, which satisfies the 30-ns NF R/W cycle requirement.
board/freescale/mx6qsabrelite/README explain a procedure to
update the SPI-NOR on the SabreLite board without Freescale
manufacturing tool but following this procedure leads to both
"sf erase" and "sf write" failing on a mx6qsabrelite board:
MX6QSABRELITE U-Boot > sf probe 1
MX6QSABRELITE U-Boot > sf erase 0 0x40000
SPI flash erase failed
MX6QSABRELITE U-Boot > sf write 0x10800000 0 0x40000
SPI flash write failed
This is because the chip-select 1 is wrong and the correct
value is 0x7300.
Since commit c1173bd0 ("sf command: allow default bus and chip selects")
the chip-select and bus arguments for the sf probe command are optional
so let's just remove it and use "sf probe" instead.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
When booting a Freescale kernel 3.0.35 on a Wandboard solo, the get_board_rev()
returns 0x62xxx, which is not a value understood by the VPU
(Video Processing Unit) library in the kernel and causes the video playback to
fail.
The expected values for get_board_rev are:
0x63xxx: For mx6quad/dual
0x61xxx: For mx6dual-lite/solo
So adjust get_board_rev() accordingly and make it as weak function, so that we
do not need to define it in every mx6 board file.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
Maximum bus width supported by some i.MX6 boards is not 8bit like
others. In case where both host controller and card support 8bit transfers,
they agree to communicate on 8bit interface while some boards support only 4bit interface.
Due to this reason the mmc 8bit default mode fails on these boards. To rectify this,
define maximum bus width supported by these boards (4bit). If max_bus_width is not
defined, it is 0 by default and 8bit width support will be enabled in host
capabilities otherwise host capabilities are modified accordingly.
It is tested with a MMCplus card.
Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com>
cc: stefano Babic <sbabic@denx.de>
cc: Andy Fleming <afleming@gmail.com>
Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
The u-boot.imx binary is generated by default, so no need to pass it in the
'make' line.
Adds support for 'bmode' command which let user to choose where to
boot from; this allows U-Boot to load system from another storage
without messing with jumpers.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This changes the code so in case an unkown value is passed it will
return as invalid.
This documents the SD card identifier so it is easier for user to spot
which card number will be used, if need.
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Turn __bss_start and __bss_end__ from linker-generated
to compiler-generated symbols, causing relocations for
these symbols to change type, from R_ARM_ABS32 to
R_ARM_RELATIVE.
This should have no functional impact, as it affects
references to __bss_start and __bss_end__ only before
relocation, and no such references are done.
Only define enabled clocks in the config file and enable
the clocks in common code.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Remove CSx configurations from board code and only define
required CSx macros in the board config file to configure
chip select windows and parameters.
Provide a structure for accessing HDMI registers, so that we can use proper
read/write accessors.
Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
Adjust HW_DRAM_CTL14 to enable the chip selects to allow usage of full
128MB of RAM.
Rename all i.MX6 pad declarations to MX6_PAD_x, so a board
may support either i.MX6Quad/Dual (MX6Q) or i.MX6Dual-Lite/Solo
(MX6DL) by including the proper header.
Boards mx6qarm2, mx6qsabreauto, mx6qsabrelite, and mx6qsabresd
only support MX6Q, so they include mx6q_pins.h.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
