Instead of passing the total RAM size via PHYS_SDRAM_SIZE option,
we should better use imx_ddr_size() function, which automatically
determines the RAM size.
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
Get the clocks from FPGA through I2C, if IFC is disabled.
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The LBMAP switches on the board will tell which boot device is used.
Only QSPI boot is supported if the boot device is IFCCard.
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h
The current pad DSE for QSPI is 60ohm. This setting cause
too strong drive to clock and data signals. Need to change
the DSE to 120ohm for better signal quality.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Q901 is PMOS, LCD_nPWREN should be at low voltage then output is 3V3.
If LCD_nPWREN is high, output is 2.4V which is not correct.
Fix 74LV OE gpio index. gpio index is wrong,
so gpio output will not have effect, since we
use wrong GPIO5_IO18, but not correct GPIO5_IO8.
And at the end of the initialization of 74lv init, should
keep OE voltage level at LOW to make 74lv output the correct
voltage.
LCD_PWR_EN controls the G pin of Q13 PMOS which needs low voltage to connect
D to S for outputting LCD 3.3V. If LCD_PWR_EN is high, we measured the LCD 3v3
is actually 1.2V.
Signed-off-by: Ye Li <ye.li@nxp.com>
Currently the LVDS backlight does not work in U-Boot after a “reboot” comand
in the kernel.
This problem occurs because the kernel uses this pin in PWM mode and U-Boot
does not configure the backlight pin as GPIO functionality.
So fix the problem by explicitly configuring the backlight pin as GPIO in
U-Boot.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
This patch is doing the following:
1. Implementing the errata for LS2080.
2. Adding fixup for fdt for LS2080.
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Add initial support for NXP's S32V234 SoC and S32V234EVB board.
The S32V230 family is designed to support computation-intensive applications
for image processing. The S32V234, as part of the S32V230 family, is a
high-performance automotive processor designed to support safe
computation-intensive applications in the area of vision and sensor fusion.
Code originally writen by:
Original-signed-off-by: Stoica Cosmin-Stefan <cosminstefan.stoica@freescale.com>
Original-signed-off-by: Mihaela Martinas <Mihaela.Martinas@freescale.com>
Original-signed-off-by: Eddy Petrișor <eddy.petrisor@gmail.com>
Signed-off-by: Eddy Petrișor <eddy.petrisor@nxp.com>
This patch adds QSPI boot support for LS2080AQDS board.
The QSPI boot image need to be programmed into the QSPI flash
first. Then we can switch to booting from QSPI memory space.
Signed-off-by: Yuan Yao <yao.yuan@nxp.com>
When QSPI is enabled, NOR flash and QIXIS can't be accessed
through IFC due to pin mux. Enable I2C QIXIS access and I2C
early init to read the sysclk and ddrclk.
QSPI module output SCLK divisor value is configured through SCFG.
Environment variable mcinitcmd is defined to initiate MC and DPL
deployment from the location where it is stored (NOR, NAND, SD, SATA,
USB) during booting. If this variable is not defined then macro
MC_BOOT_ENV_VAR will be null and MC will not be booted and DPL will
not be applied during U-boot booting.
Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
No intended functional change, just remove redundancies in some
Makefiles, and make whitespace aesthetics uniform.
We should use unified setup_ddr_tlbs() for spl boot and non-spl boot
to make sure 'M' bit is set for DDR TLB to maintain cache coherence.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
For malloc to work in SPL framework enable GD_FLG_FULL_MALLOC_INIT
flag in global data after allocating memory using mem_malloc_init.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
These functions are part of the Linux 4.6 sync. They are being added
before the main sync patch in order to make it easier to address the
issue across all NAND drivers (many/most of which do not closely track
their Linux counterparts) separately from other merge issues.
Signed-off-by: Scott Wood <oss@buserror.net>
QorIQ LS1012A FREEDOM (LS1012AFRDM) is a high-performance
development platform, with a complete debugging environment.
The LS1012AFRDM board supports the QorIQ LS1012A processor and is
optimized to support the high-bandwidth DDR3L memory and
a full complement of high-speed SerDes ports.
Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
QorIQ LS1012A Reference Design System (LS1012ARDB) is a high-performance
The LS1012ARDB board supports the QorIQ LS1012A processor and is
QorIQ LS1012A Development System (LS1012AQDS) is a high-performance
The LS1012AQDS board supports the QorIQ LS1012A processor and is
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Add QIXIS_LBMAP_BRDCFG_REG to the save offset of LBMAP
configuration register instead of hardcoding it in
set_lbmap() function.
Check if qixis supports memory-mapped read/write
before compiling IFC based qixis read/write functions.
SoC overviews are getting repeated across board folders.
So, Organize SoC overview at common location i.e. fsl-layerscape/doc
Also move README.lsch2 and README.lsch3 in same folder.
SCFG_USBPWRFAULT_DEDICATED instead of SCFG_USBPWRFAULT_SHARED should
be used for USB 3 & 2.
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
U-Boot should continue to work without management complex (MC).
Fix compiling errors and warnings.
Signed-off-by: York Sun <york.sun@nxp.com>
LS102A ref manual dictates that ICID have to be written to the MSB
of the ICID register, not to the LSB.
Signed-off-by: Vincent Siles <vincent.siles@provenrun.com>
This patch updates clk_adjust to actual value for boards with
T-series and LS-series SoCs to match the setting of clk_adjust
in latest ddr driver.
Fix the brace indentation in board_mmc_init().
Signed-off-by: Sebastien Bourdelin <sebastien.bourdelin@savoirfairelinux.com>
In 'commit d584c68ce0f5bf2f430ccfb2ba00bd506206fb91',
ar8031 is changed to use ar8035_config. ar8035_config
actually does the same thing as mx6_rgmii_rework, so
drop mx6_rgmii_rework and board_phy_config.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT:
config OF_BOARD_SETUP
bool "Set up board-specific details in device tree before boot"
depends on OF_LIBFDT
remove superfluous tests of CONFIG_OF_LIBFDT when testing for
CONFIG_OF_BOARD_SETUP.
[trini: Typo fix: s/ifdefi/ifdef/]
Disable the non-existent ethernet ports on T4240RDB:FM1_DTSEC5,
FM1_DTSEC6, FM2_DTSEC5 and FM2_DTSEC6.
Signed-off-by: Ying Zhang <ying.zhang22455@nxp.com>
Use simpler runtime cpu dection macros.
CC: Shengzhou Liu <Shengzhou.Liu@nxp.com>
To use AQR105 PHY's interrupt, we need to invert the IRQ pin polarity
by setting relative bit in SCFG_INTPCR register, because AQR105
interrupt is low active but GIC accepts high active.
Some SOCs, specifically the ones in the C29x familiy can have
multiple security engines. This patch adds a system configuration
define which indicates the maximum number of SEC engines that
can be found on a SoC.
Signed-off-by: Alex Porosanu <alexandru.porosanu@nxp.com>
Using u16 for cfg_rcw_src and u8 for sd1refclk_sel is enough.
gd->env_addr will be initialized in env_init() in
common/env_nowhere.c if CONFIG_ENV_IS_NOWHERE is defined.
So no need to do it again.
