(Bug Id 3536) 2. Environment (Bug Ids 3577, 3578)
* SYSCLK changes for P2020RDB RevC
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
configuration and SYSCLK values.
P2020RDB RevB changes mainly for DDR settings
DDR size configurable according to Board Rev and SOC.
If GPIO11 = 0... REV A board (512MB P2020 and 256MB P1020)
If GPIO11 = 1... REV B board (1GB P2020 and 256MB P1020)
Switch options for NAND boot are SW[1:4]='0101"
To Boot from NAND
1. tftp 1000000 u-boot-nand.bin
2. nand erase 0 80000
3. nand write 1000000 0 80000
4. Change the Switch settings to boot from NAND.
5. reset the board.
SYSCLK getting detected from GPIO10
If GPIO10 = 0... SYSCLK = 66Mhz
If GPIO10 = 1... SYSCLK = 50Mhz
Board REV getting detected from GPIO11
If GPIO11 = 1... REV B board.
SDCARD boot support for P2020RDB
Make a special uboot used for booting from SDcard for P2020RDB platform.
This patch uses sdboot support for 8536DS posted by Mingkai Hu.
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
SD and SPI 4-bit data transfer mode selected
Make both[SD and SPI] work at the same time.
Make a special uboot used for booting from SDcard or SPI flash
This Patch is borrowed from MPC8536DS SD Card Boot.
This patch is used to generate a special version u-boot,
together with the data structure on the SDcard/SPI flash,
can be used to booting from SDcard/SPI flash on 8536DS board.
The boot ROM in CPU and the data structure on SD card will initialize
the DDR, set a large tlb0 for DDR and CCSR, set law0 for DDR. The special
version uboot avoid initializing the DDR. Try to reseve the law0 for DDR
by adding a CONFIG_SYS_RESERVED_LAW0 macro for the "dynamic law allocation"
code. But keep the original tlb initialize code for DDR, disabled the large
tlb0 which was set in the boot ROM.
This patch is intend for those who are interested in the function of
booting from SD card on 8536DS board and not for opensource.
An utility is needed to write the data structure and the special
version u-boot onto the SD card which has filesystem on it or onto
the SPI flash.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Add eSPI controller support under the SPI framework.
This Patch borrowed from MPC8536DS SPI Support.
Support for P20x0 RDB Platforms.
The Nand flash was unable to read and write properly
due to Nand Chip Select (nCE) setup was in reverse
order. Also, increase the Nand time out value to 60.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
These were left in accidentally, and are not really useful unless the
code is as broken as it was when it was being developed.
Signed-off-by: Andy Fleming <afleming@freescale.com>
lib_ppc/board.c
The SerDes initialization should be finished before negating the reset
signal according to the reference manual. This isn't an issue on real
hardware, but we'd better stick to the specifications anyway.
Suggested-by: Liu Dave <DaveLiu@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe
slots. Let's support them.
If 36-bit addressing is enabled, print a message on the console
when we boot.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Update the 86xx reset sequence to try executing a board-specific reset
function. If the board-specific reset is not implemented or does not
succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard
reset procedure than the previous method and allows all board
peripherals to be reset if needed.
Added some info that is printed out when we boot to distiquish if we
built MPC8572DS_config vs MPC8572DS_36BIT_config since they have
different address maps.
The device tree's PHY addresses need to be fixed up if we're using the
SGMII Riser Card.
The 8572, 8536, and 8544 DS boards were modified to call this function.
Code idea taken from Liu Yu <yu.liu@freescale.com>
In the 36-bit physical config for MPC8572DS when need the start address
of memory and it size to be kept in phys_*_t instead of a ulong since
we support >4G of memory in the config and ulong cant represent that.
Otherwise we end up seeing the memory node in the device tree reporting
back we have memory starting @ 0 and of size 0.
When we introduced the 36-bit config of the MPC8572DS board we had the
wrong PCI MEM bus address map. Additionally, the change to the address
map exposes a small issue in our dummy read on the ULI bus. We need
to use the new mapping functions to handle that read properly in the
36-bit config.
Clean up PCI mapping concepts in the 8641 config - rename _BASE
to _BUS, as it's actually a PCI bus address, separate virtual
and physical addresses into _VIRT and _PHYS, and use each
appopriately.
Because the inbound pci windows are mapped generously, set up
the more specific outbound windows first. This way, when we
search the pci regions for something, we will hit on the more
specific region. This can actually be a problem on systems
with large amounts of RAM.
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
The diufb command usage formatting is non-standard. It was
made standard in preparation for larger command usage updates.
Rather than have the board code initialize SATA automatically during boot,
make the user manually run "sata init". This brings the SATA subsystem in
line with common U-Boot policy.
Rather than having a dedicated weak function "is_sata_supported", people
can override sata_initialize() to do their weird board stuff. Then they
can call the actual __sata_initialize().
The wake up ARP feature need use the memory to process
wake up packet, we enable auto self refresh to support it.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Introduce a new define to seperate out the virtual address that PCI
IO space is at from the physical address. In most situations these are
mapped 1:1. However any code accessing the bus should use VIRT.
memory is at from the physical address. In most situations these are
Use the _MEM_PHYS defines instead of _MEM_BUS for LAW and real address fields
of TLBs. This is what we should have always been using from the start.
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead
of _IO_BASE so we are more explicit.
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead
of _MEM_BASE so we are more explicit.
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and
maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash.
This allows us to deal with 36-bit phys on these boards in the future.
Added a PIXIS_BASE_PHYS for use as the physical address and maintain
PIXIS_BASE as the virtual address of the PIXIS fpga registers.
MPC837XEMDS boards can support PCI-E via "PCI-E riser card". The card
provides two PCI-E (x2) ports. Though, only one port can be used in x2
mode. Two ports can function simultaneously in x1 mode.
PCI-E x1/x2 modes can be switched via "pex_x2" environment variable.
MPC8315ERDB boards features PCI-E x1 and Mini PCI-E x1 ports. Let's
support them.
When running in PCI agent mode, the PCI_CLK_OUT signals are not used, so do
not enable them. See the MPC8349EA Reference Manual, Section 4.4.2
"Clocking in PCI Agent Mode".
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
- Move the TLB entry of PIXIS_BASE from TLB0 to TLB1[8], because in CAMP mode,
all the TLB0 entries will be invalidated after cpu1 brings up kernel, thus cpu0
can not access PIXIS_BASE anymore (any access will cause DataTLBError exception)
- Set CONFIG_SYS_DDR_TLB_START to 9 for MPC8572DS board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The IO port selection for MPC8544DS board:
Port cfg_io_ports
PCIE1 0x2, 0x3, 0x4, 0x5, 0x6, 0x7
PCIE2 0x4, 0x5, 0x6, 0x7
PCIE3 0x6, 0x7
This patch changes the PCIE12 and PCIE2 logic more readable.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
PCIE2 and PCIE3 should be decided by corresponing bit in devdisr instead of
PCIE1 bit.
On MPC8572DS board, PCIE refers to PCIE1.
