path: root/board/freescale/vf610twr
2018-05-01MAINTAINERS: Switch nxp.com domainFabio Estevam
freescale.com domain is no longer reachable, so switch the maintainers' emails to nxp.com domain instead. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2015-10-16vf610twr: Fix typo in DRAM initAnthony Felice
This commit fixes a typo in vf610twr DRAM init that was causing a hang in U-Boot for the Vybrid Tower. This typo was introduced in commit 3f353cecc (vf610: refactor DDRMC code). Signed-off-by: Anthony Felice <tony.felice@timesys.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-02vf610: refactor DDRMC codeAlbert ARIBAUD \\(3ADEV\\)
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-23ARM: vf610: Enable external 32KHz oscillatorStefan Agner
Enable the SCSC (Slow Clock Source Controller) and select the external 32KHz oscillator. This improves the accuracy of the RTC. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-04-23ARM: vf610: Move DDR3 initialization to imx-commonSanchayan Maity
In order to avoid code duplication, move the DDR3 initialization to the common place under imx-common. Currently ROW_DIFF and COL_DIFF can be chosen from the board file. The JEDEC timings are specified using a common ddr3_jedec_timings structure. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-07vf610twr: Tune DDR initialization settingsAnthony Felice
Removed settings in unsupported register fields. They didn’t do anything, and in most cases, were not documented in the reference manual. Changed register settings to comply with JEDEC required values. Changed timing parameters because they included full clock periods that were doing nothing. Signed-off-by: Anthony Felice <tony.felice@timesys.com> [rebased on v2014.10-rc2] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-09-22Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-09-17imx: Fix warning by building vf610twr_nandStefano Babic
commit d6d07a9b... arm: vf610: add NAND support for vf610twr generates the following warnings: WARNING: no status info for 'vf610twr_nand' WARNING: no maintainers for 'vf610twr_nand'WARNING: no status info for 'vf610twr_nand' This is due to the fact that vf610twr_nand_defconfig has no Maintainer. This patch proposed Alison as Maintainer and fix it. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Alison Wang <b18965@freescale.com> CC: Stefan Agner <stefan@agner.ch>
2014-09-16arm: vf610: add NAND support for vf610twrStefan Agner
This adds NAND support for the Vybrid tower system (TWR-VF65GS10) provided by the vf610_nfc driver. Full 16-Bit bus width is supported. Also an aditional config vf610twr_nand is introduced which gets the environment from NAND. However, booting U-Boot from NAND is not yet possible due to missing boot configuration block (BCB). Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-06-09arm: vf610: Add QSPI support for VF610TWRChao Fu
Add QSPI support for VF610TWR, such as clock and iomux. Signed-off-by: Alison Wang <Huan.Wang@freescale.com> Signed-off-by: Chao Fu <b44548@freescale.com>
2014-05-25arm: vf610: add DDR_SEL_PAD_CONTR registerStefan Agner
Set DDR_SEL_PAD_CONTR register explicitly to DDR3 which solves RAM issues with newer silicon (1.1). This register was added in revision 4 of the Vybrid Reference Manual. Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-04-07arm: vf610: fix double iomux configuration for vf610twr boardMarcel Ziswiler
Get rid of double VF610_PAD_DDR_A15__DDR_A_15 iomux configuration. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23vf610: Add I2C support for Vybrid VF610 platformAlison Wang
This patch adds I2C support for Vybrid VF610 platform and adds I2C0 support to VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com>
2013-06-06vf610twr: Drop unneeded 'status' variableFabio Estevam
No need to use the 'status' variable, so just remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-03arm: vf610: Add basic support for Vybrid VF610TWR boardAlison Wang
VF610TWR is a board based on Vybrid VF610 SoC. This patch adds basic support for Vybrid VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
