path: root/board/freescale/t4rdb/pci.c
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-05-13powerpc/85xx: Add T4240RDB board supportChunhe Lan
T4240RDB board Specification ---------------------------- Memory subsystem: 6GB DDR3 128MB NOR flash 2GB NAND flash Ethernet: Eight 1G SGMII ports Four 10Gbps SFP+ ports PCIe: Two PCIe slots USB: Two USB2.0 Type A ports SDHC: One SD-card port SATA: One SATA port UART: Dual RJ45 ports Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> [York Sun: fix CONFIG_SYS_QE_FMAN_FW_ADDR in T4240RDB.h]
