path: root/board/freescale/t104xrdb
2014-09-24powerpc/t104xrdb: Add Support of rcw for T1042RDB in u-bootvijay rai
This patch adds support of rcw for T1042RDB, it makes following changes : - Adds t1042_rcw.cfg file for serdes protocol 0x86 for T1042RDB - Renames t1042_pi_rcw.cfg file from t1042_rcw.cfg and also updates comments for valid serdes protocol which is 0x06 - Also updates CONFIG_SYS_FSL_PBL_RCW for T1042RDB Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-12powerpc/t104xrdb: support deep sleep in SPI/SD bootTang Yuantian
Add deep sleep support in SPI/SD boot. The destination address second stage uboot image is loaded to is changed because currently this address will be used by kernel which means we can't reserve it for resume. Entry point to kernel is still placed in second stage uboot. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-12powerpc/t1042RDB: Add Video - HDMI supportJason Jin
T1042 has internal display interface unit (DIU) for driving video. T1042RDB supports video mode via -LCD using TI enconder -HDMI type interface via HDMI encoder Chrontel, CH7301C encoder which is I2C programmable is used as HDMI connector on T1042RDB. This patch add support to -enable Video interface for T1042RDB -route qixis multiplexing to enable DIU-HDMI interface on board -program DIU pixel clock gerenartor for T1042 -program HDMI encoder via I2C on board This patch refer to the upstream diu patch (337b0c52b3296f371d04aef71a833e09110e0e6b) for T1040qds. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> [York Sun: resolve conflict and move changes to T104xRDB.h] Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2014-05-16powerpc/t104xrdb: Toggle deep sleep management signals after resumeTang Yuantian
T104xrdb has several sleep management signals that are used for deep sleep. They are enabled by OS to enter deep sleep and should be disabled by u-boot when cores wake up. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/t1040rdb: added a break in switch caseShaohui Xie
There should be a break for case PHY_INTERFACE_MODE_SGMII, otherwise it will fall into case PHY_INTERFACE_MODE_RGMII. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22board/t104xrdb: Add support of NAND, SD, SPI boot for T104xRDBPrabhakar Kushwaha
Add support of 2 stage NAND, SD, SPI boot loader using SPL framework. here, PBL initialise the internal SRAM and copy SPL(160KB). This further initialise DDR using SPD and environment and copy u-boot(768 KB) from NAND to DDR. Finally SPL transer control to u-boot. Initialise/create followings required for SPL framework - Add spl.c which defines board_init_f, board_init_r - update tlb and ddr accordingly Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx: Add deep sleep support on T104xRDBTang Yuantian
Add deep sleep support on T104xRDB platforms. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22board/t104xrdb: Add support of CPLDPrabhakar Kushwaha
T1040RDB and T1042RDB_PI has CPLD. Here CPLD controls board mux/features. This support of CPLD includes - files and register defintion - Commands to swtich alternate bank and default bank Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc/t104xrdb: Update DDR initialization related settingsPriyanka Jain
Update following DDR related settings for T1040RDB, T1042RDB_PI -Correct number of chip selects to two as t1040 supports two Chip selects. -Update board_specific_parameters udimm structure with settings derived via calibration. -Update ddr_raw_timing sructure corresponding to DIMM. -Set ODT to off. Typically on FSL board, ODT is set to 75 ohm, but on T104xRDB, on setting this , DDR instability is observed. Board-level debugging is in progress. Verified the updated settings to be working fine with dual-ranked Micron, MT18KSF51272AZ-1G6 DIMM at data rate 1600MT/s. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-03powerpc/t104xrdb: Add basic ethernet supportPriyanka Jain
This covers only non-L2 switch ethernet interfaces i.e. RGMII and SGMII interface for both T1040RDB and T1042RDB_PI T1040RDB is configured as serdes protocol 0x66 which can support following interfaces 2 RGMIIS on DTSEC4, DTSEC5 1 SGMII on DTSEC3 T1042RDB_PI is configured as serdes protocol 0x06 which can support following interfaces 2 RGMIIS on DTSEC4, DTSEC5 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: Minor change in commit message] Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-03powerpc/mpc85xx:Fix README to show correct flash memory mapPrabhakar Kushwaha
Due to increased size of u-boot, FMAN ucode start address has been shifted by 256KB causing a overlap with rootfs start address. Update rootfs start address to reflect correct memory map. Also fix minor typo in README Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1042RDB_PI board supportPriyanka Jain
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market. T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1040RDB board supportPriyanka Jain
T1040RDB is Freescale Reference Design Board supporting the T1040 QorIQ Power Architecture™ processor. T1040RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: - PCI - SGMII - QSGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Devices connected: EEPROM, thermal monitor, VID controller - Other IO - Two Serial ports - ProfiBus port Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefile] Acked-by: York Sun <yorksun@freescale.com>
