path: root/board/freescale/t1040qds
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-08-02board/freescale: Update MAINTAINERS filesYork Sun
Update maintainers for secure boot targets. Signed-off-by: York Sun <york.sun@nxp.com>
2016-06-03board/freescale: Update ddr clk_adjustShengzhou Liu
This patch updates clk_adjust to actual value for boards with T-series and LS-series SoCs to match the setting of clk_adjust in latest ddr driver. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-25powerpc: mpc85xx: Move set_liodns, setup_portals to common boot seqPrabhakar Kushwaha
Users migrating Freescale's PowerPC SoC U-Boot code to their custom board, often overlook the need to execute set_liodns() and setup_portals() being called by platform files. So Move set_liodns() and setup_portals() to common u-boot boot sequence Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-29net: Move some header files to include/Shaohui Xie
The fsl_dtsec.h & fsl_tgec.h & fsl_fman.h can be shared on both ARM and PPC, move it out of ppc to include/, and change the path in drivers accordingly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-01powerpc/defconfig: Rename defconfig file for T1040QDS/T1024QDS DDR4 targetsYork Sun
Previously the DDR4 targets were named with _D4. Rename them with _DDR4 for easy identification. Signed-off-by: York Sun <yorksun@freescale.com>
2015-07-28powerpc/t104x, t102x: Update CPC debug register value in PBI commandsPriyanka Jain
Update PBI command in pbi_cfg files to keep register bit to default reset value while configuring CPC as SRAM Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-21board/T1040qds: Add VSC9953 support for T1040qds boardCodrin Ciubotariu
This patch configures and initializes the L2 switch on T1040QDS board. The L2 switch ports must be initialized according to the SerDes protocols. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
2015-01-21board/T1040qds: T1040 FMAN ports FM1@DTSEC1 and FM1@DTSEC2 have no PHYsCodrin Ciubotariu
Freescale's T1040qds board may be configured to have up to 5 FMAN ports (FM1@DTSEC1 to FM1@DTSEC5). From these 5 ports, 2 of them may be fixed-links (FM1@DTSEC1 annd FM1@DTSEC2), connected to other two ports from an intergrated VSC9953 L2 Switch (switch ports 8 and 9). These fixed-link ports have no PHYs attatched, so they don't have a corresponding MDIO. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-21board/T1040qds: Fix lane-to-slot mapping for SerDes protocol 0x89Codrin Ciubotariu
2015-01-16mpc85xx/t1040qds: convert deep sleep to generic board interfacetang yuantian
A new deep sleep interface is introduced to support generic board structure. Converts it to use new interface. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24board/t1040qds: Add sgmii ports support in 0xA7 protocolPriyanka Jain
T1042QDS (T1042 is T1040 Personality without L2 switch) supports following sgmii interfaces with serdes protocol 0xA7 -SGMII-MAC3 on Lane B - slot 7 -SGMII-MAC5 on Lane H - slot 7 -SGMII2.5G-MAC1 on Lane C - slot 6 -SGMII2.5G-MAC2 on Lane D - slot 5 Add support of above sgmii interfaces Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2014-08-12fsl/diu: ch7301 encoder split off from t1040qds/diu.cWang Dongsheng
The ch7301 encoder not only used in t1040qds platform, so we split it for t1042rdb and LSx platform. Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/t1040qds: Initialize EPHY2 clock to RGMII onlyvijay rai
Setting FPGA register brdcfg9 EPHY2 bits to '0' to initialize EPHY2 clock to RGMII mode. Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22T1040QDS/U-QE: Add u-qe support to t1040qdsZhao Qiang
Add u-qe support for t1040qds Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx: Add deep sleep support on T1040QDSTang Yuantian
Add deep sleep support on T1040QDS platform. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx/T1040QDS_D4: Add DDR4 supportYork Sun
T1040QDS_D4 is a variant of T1040QDS, with additional circuit to support DDR4 memory. Tested with MTA9ASF51272AZ-2G1AYESZG. Signed-off-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc/t1040qds: Add Video - HDMI supportPriyanka Jain
T1040 has internal display interface unit (DIU) for driving video. T1040QDS supports video mode via -LCD using TI enconder -HDMI type interface via HDMI encoder Chrontel, CH7301C encoder which is I2C programmable is used as HDMI connector on T1040QDS. This patch add support to -enable Video interface for T1040QDS -route qixis multiplexing to enable DIU-HDMI interface on board -program DIU pixel clock gerenartor for T1040 -program HDMI encoder via I2C on board Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-03boards/t1040qds: Adds ethernet support for T1040Prabhakar Kushwaha
Enable entherent for T1040QDS. It enables FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5 Define MDIO related configs Added eth.c file Update t1040.c to support RGMII and SGMII Update t1040qds.c to support ethernet Define the PHY address Signed-off-by: Arpit Goel <B44344@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: remove dash from commit message] Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-03powerpc/mpc85xx:Fix README to show correct flash memory mapPrabhakar Kushwaha
Due to increased size of u-boot, FMAN ucode start address has been shifted by 256KB causing a overlap with rootfs start address. Update rootfs start address to reflect correct memory map. Also fix minor typo in README Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc/t1040qds: Update DDR initialization related settingsPriyanka Jain
Update following DDR related settings for T1040QDS -Correct number of chip selects to two as t1040qds supports two Chip selects. -Update board_specific_parameters udimm structure with settings derived via calibration. -Reduced I2C speed to 50KHz as DDR-SPD does not get reliably read at 400KHz. Verified the updated settings to be working fine with dual-ranked Micron, MT18KSF51272AZ-1G6 DIMM at data rate 833MT/s, 1333MT/s and 1600MT/s. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-02board/t1040qds: Enable memory reset controlPrabhakar Kushwaha
Define QIXIS_RST_FORCE_MEM to reset on-board DDR-DIMM before start accessing it. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-02board/t1040qds: Fix typo in t1040_pbi.cfg filePrabhakar Kushwaha
T1040QDS has 256KB SRAM. Comment is showing wrong information. So update the comment. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-17Makefile: specifiy an explicite object name rather than $(BOARD).oMasahiro Yamada
2013-11-13powerpc/t1040: enable PBL tool for T1040Prabhakar Kushwaha
Use a default RCW of protocol 0x66. A PBI configure file which uses CPC as 256KB SRAM. It can be used by PBL tool on T1040 to build a pbl boot image. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-01board: powerpc: convert more makefiles to Kbuild styleTom Rini
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: York Sun <yorksun@freescale.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-10-24fsl/mpc85xx: define common serdes_clock_to_string functionValentin Longchamp
This allows to share some common code for the boards that use a corenet base SoC. Two different versions of the function are available in fsl_corenet_serdes.c and fsl_corenet2_serdes.c files. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix t1040qds.c] Acked-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc/t1040qds: Add T1040QDS boardPrabhakar Kushwaha
T1040QDS is a high-performance computing evaluation, development and test platform supporting the T1040 QorIQ Power Architecture™ processor. T1040QDS board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: — PCI Express: supporting Gen 1 and Gen 2; — SGMII — QSGMII — SATA 2.0 — Aurora debug with dedicated connectors - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 8-bit, async, up to 2GB. - NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB - GASIC: Simple (minimal) target within Qixis FPGA - PromJET rapid memory download support - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - QIXIS System Logic FPGA - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - Video - DIU supports video at up to 1280x1024x32bpp - USB - Supports two USB 2.0 ports with integrated PHYs — Two type A ports with 5V@1.5A per port. — Second port can be converted to OTG mini-AB - SDHC - SDHC port connects directly to an adapter card slot, featuring: - Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC — Supporting eMMC memory devices - SPI - On-board support of 3 different devices and sizes - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: fix conflict in boards.cfg] Acked-by-by: York Sun <yorksun@freescale.com>
