path: root/board/freescale/p2020ds
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc: Fix CamelCase warnings in DDR related codePriyanka Jain
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with embedded acronyms capitalized that trigger the CamelCase warning in checkpatch.pl Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2012-11-278xxx: Change all 8*xx_DDR addresses to 8xxxAndy Fleming
There were a number of shared files that were using CONFIG_SYS_MPC85xx_DDR_ADDR, or CONFIG_SYS_MPC86xx_DDR_ADDR, and several variants (DDR2, DDR3). A recent patchset added 85xx-specific ones to code which was used by 86xx systems. After reviewing places where these constants were used, and noting that the type definitions of the pointers assigned to point to those addresses were the same, the cleanest approach to fixing this problem was to unify the namespace for the 85xx, 83xx, and 86xx DDR address definitions. This patch does: s/CONFIG_SYS_MPC8.xx_DDR/CONFIG_SYS_MPC8xxx_DDR/g All 85xx, 86xx, and 83xx have been built with this change. Signed-off-by: Andy Fleming <afleming@freescale.com> Tested-by: Andy Fleming <afleming@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2012-07-06powerpc/85xx: Add USB device-tree fixup for various platformsramneek mehresh
Add USB device-tree fixup for following platforms: MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-10-18powerpc/85xx: Fix P2020DS bootingKumar Gala
The following commit removed the code that set odt_rd_cfg and odt_wr_cfg. With out this code P2020DS board will not boot: commit 712cf7ab0b58e51a69e339397457d3591b6b650e Author: York Sun <yorksun@freescale.com> Date: Mon Oct 3 09:19:53 2011 -0700 powerpc/mpc8xxx: Merge entries in DDR speed table Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8xxx: Merge entries in DDR speed tableYork Sun
It is not necessary to keep multiple entries for the same setting in DDR speed tables. Merge them for smaller tables. Also restructure the tables for smaller size. Cleanup some typedefs. Enforce strict checking for speed table. If DIMM is running at higher than known speed, try to use the highest speed setting. If rank is unknown, it has to panic. Removed ODT overriding for P2020DS as it is not necessary. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc85xx: Display a warning for unsupported DDR data ratesYork Sun
If DDR initialziation uses a speed table and the speed is not matched, print a warning message instead of silently ignoring. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-20tsec: Convert tsec to use PHY LibAndy Fleming
This converts tsec to use the new PHY Lib. All of the old PHY support is ripped out. The old MDIO driver is split off, and placed in fsl_mdio.c. The initialization is modified to initialize the MDIO driver as well. The powerpc config file is modified to configure PHYLIB if TSEC_ENET is configured. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-04powerpc/85xx: Enable eSDHC boot support on P2020 DSJerry Huang
We implement our own mmc_get_env_addr since the environment variables are written to just after the u-boot image on SDCard, so we must read the MBR to get the start address and code length of the u-boot image, then calculate the address of the env. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc: Move cpu specific lmb reserve to arch_lmb_reserveKumar Gala
We've been utilizing board_lmb_reserve to reserve the boot page for MP systems. We can just move this into arch_lmb_reserve for 85xx & 86xx systems rather than duplicating in each board port. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add eSDHC support on P2020DSJerry Huang
We enable SDHC_CD and SDHC_WP signals (pin muxed with GPIO8 & GPIO9 respectively). We enable EXT2, FAT, and parition support for both MMC & USB configs. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Move RESET_VECTOR_ADDRESS into config.hKumar Gala
Rather than defining it config.mk we can set it in config.h and remove config.mk from several boards that don't need it. We mimic what 4xx does and introduce CONFIG_RESET_VECTOR_ADDRESS for config.h to set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/85xx: Rework P2020DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in P2020DS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Cleanup SGMII detection and reportingKumar Gala
Use new is_serdes_configured to determine if TSECs are in SGMII mode and report that on the various boards that use or can be configured in SGMII mode in board_eth_init() instead of in the PCI init code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/8xxx: Replace is_fsl_pci_cfg with is_serdes_configuredKumar Gala
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can replace the is_fsl_pci_cfg() code with the is_serdes_configured(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-30hwconfig: Fix dummy initialization of {board, cpu}_hwconfigKumar Gala
Since board_hwconfig & cpu_hwconfig are defined as weak and dont have a default value they will get put into the BSS if they aren't defined elsewhere. This is problematic as we try to utilize hwconfig before we've relocated and thus BSS isn't setup. Instead of giving dummy values in the board files that utilize this feature, we can just initialize the variables to an empty string and thus move them out of the BSS if they aren't defined elsewhere. Also made board_hwconfig & cpu_hwconfig arrays to reduce size associated with string pointers vs arrays. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-14mpc85xx: Fix SERDES/eTSEC message indentationPeter Tyser
Previously some mpc85xx boards printed indented messages such as the following on bootup: printf(" eTSEC4 is in sgmii mode.\n"); printf(" Serdes2 disalbed\n"); The bootup appearance looks cleaner if the indentation is removed which aligns these messages with other bootup output. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: galak@kernel.crashing.org
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-08-31Fix parameters to support RDIMM for P2020DSYork Sun
2010-07-26powerpc/p2020ds: Integrated with P2020DS DDR change and enabled hwconfigyork
Enabled SPD Enabled DDR2 Enabled hwconfig Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/p2020: Move INIT_RAM_ADDR physical address higher for 36-bit for P2020DSyork
If 36-bit is enabled, move INIT_RAM_ADDR physical address higher to free lowest 4GB address space. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16Move ICS CLK chip frequency calculation code into a common board libraryKumar Gala
We have several boards that use the same ICS307 CLK chip to drive the System clock and DDR clock. Move the code into a common location so we share it. Convert the P2020DS board as the first to use the new common ICS307 code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Timur Tabi <timur@freescale.com>
2010-04-07p2020ds: add alternate boot bank support using the ngPIXIS FPGATimur Tabi
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS. The ngPIXIS has one distinct new feature: the values of the on-board switches can be selectively overridden with shadow registers. This feature is used to boot from a different NOR flash bank, instead of having a register dedicated for this purpose. Because the ngPIXIS is so different from the previous PIXIS, a new file is introduced: ngpixis.c. Also update the P2020DS checkboard() function to use the new macros defined in the header file. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07fsl: improve the PIXIS code and fix a few bugsTimur Tabi
Refactor and document the Freescale PIXIS code, used on most 85xx and 86xx boards. This makes the code easier to read and more flexible. Delete pixis.h, because none of the exported functions were actually being used by any other file. Make all of the functions in pixis.c 'static'. Remove "#include pixis.h" from every file that has it. Remove some unnecessary #includes. Make 'pixis_base' into a macro, so that we don't need to define it in every function. Add "while(1);" loops at the end of functions that reset the board, so that execution doesn't continue while the reset is in progress. Replace in_8/out_8 calls with clrbits_8, setbits_8, or clrsetbits_8, where appropriate. Replace ulong/uint with their spelled-out equivalents. Remove unnecessary typecasts, changing the types of some variables if necessary. Add CONFIG_SYS_PIXIS_VCFGEN0_ENABLE and CONFIG_SYS_PIXIS_VBOOT_ENABLE to make it easier for specific boards to support variations in the PIXIS registers sets. No current boards appears to need this feature. Fix the definition of CONFIG_SYS_PIXIS_VBOOT_MASK for the MPC8610 HPCD. Apparently, "pixis_reset altbank" has never worked on this board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2010-01-05ppc/85xx: Map boot page guarded for MP bootKumar Gala
We already map the page cache-inhibited. There is no reason we shouldn't also be marking it guarded to prevent speculative accesses. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Make flash TLB entry determined at runtime on FSL boardsKumar Gala
Rather than hard coding which TLB entry the FLASH is mapped with we can use find_tlb_idx to determine the entry. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Move to using fsl_setup_hose on P2020 DSKumar Gala
We can use fsl_setup_hose to determine if we are a agent/end-point or a host. Rather than using some SoC specific register we can just look at the PCI cfg space of the host controller to determine this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-04Revert "ppc/85xx/pci: fsl_pci_init: pcie agent mode support"Kumar Gala
This reverts commit 70ed869ea5f6b1d13d7b140c83ec0dcd8a127ddc. There isn't any need to modify the API for fsl_pci_init_port to pass the status of host/agent(end-point) status. We can determine that internally to fsl_pci_init_port. Revert the patch that makes the API change. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-27ppc/85xx/pci: fsl_pci_init: pcie agent mode supportVivek Mahajan
Originally written by Jason Jin and Mingkai Hu for mpc8536. When QorIQ based board is configured as a PCIe agent, then unlock/enable inbound PCI configuration cycles and init a 4K inbound memory window; so that a PCIe host can access the PCIe agents SDRAM at address 0x0 * Supported in fsl_pci_init_port() after adding pcie_ep as a param * Revamped copyright in drivers/pci/fsl_pci_init.c * Mods in 85xx based board specific pci init after this change Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
