path: root/board/freescale/p2020ds/law.c
2011-01-14powerpc/85xx: Rework P2020DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in P2020DS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add P2020DS supportSrikanth Srinivasan
The patch adds support for P2020DS reference platform. DDR3 interface uses hard-coded initialization rather than SPD for now and was tested at 667Mhz. Some PIXIS register definitions and associated code sections need to be fixed. TSEC1/2/3, NOR flash, MAC/SYS ID EEPROM, PCIE1/2/3 are all tested under u-boot. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
