This board is still a non-generic board.
Cc: Ira W. Snyder <iws@ovro.caltech.edu>
This function can fail if the device tree runs out of space. Rather than
silently booting with an incomplete device tree, allow the failure to be
detected.
Unfortunately this involves changing a lot of places in the code. I have
not changed behvaiour to return an error where one is not currently
returned, to avoid unexpected breakage.
Eventually it would be nice to allow boards to register functions to be
called to update the device tree. This would avoid all the many functions
to do this. However it's not clear yet if this should be done using driver
model or with a linker list. This work is left for later.
Acked-by: Anatolij Gustschin <agust@denx.de>
[trini: Fixup common/cmd_io.c]
Add USB device-tree fixup for following platforms:
MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
This adds support for the Freescale COM Express P2020 board. This board
is similar to the P1_P2_RDB, but has some extra (as well as missing)
peripherals.
Unlike all other mpc85xx boards, it uses a watchdog timeout to reset.
Using the HRESET_REQ register does not work.
This board has no NOR flash, and can only be booted via SD or SPI. This
procedure is documented in Freescale Document Number AN3659 "Booting
from On-Chip ROM (eSDHC or eSPI)." Some alternative documentation is
provided in Freescale Document Number P2020RM "P2020 QorIQ Integrated
Processor Reference Manual" (section 4.5).
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
