path: root/board/freescale/p1_twr
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: Fix CamelCase checkpatch warningsPrabhakar Kushwaha
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase". Convert variables name to normal naming convention and modify board, driver files with updated the new structure. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-12powerpc/mpc85xx: Cleanup license header in source filesYork Sun
Fix the license header introduced by the following patches Add TWR-P10xx board support Add T4240EMU target IDT8T49N222A configuration code Add C29x SoC support Add support for C29XPCIE board Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/mpc8xxx: Add memory reset controlYork Sun
JEDEC spec requires the clocks to be stable before deasserting reset signal for RDIMMs. Clocks start when any chip select is enabled and clock control register is set. This patch also adds the interface to toggle memory reset signal if needed by the boards. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/85xx: Add TWR-P10xx board supportXie Xiaobo
TWR-P1025 Specification: ----------------------- Memory subsystem: 512MB DDR3 (on board DDR) 64Mbyte 16bit NOR flash One microSD Card slot Ethernet: eTSEC1: Connected to Atheros AR8035 GETH PHY eTSEC3: Connected to Atheros AR8035 GETH PHY UART: Two UARTs are routed to the FDTI dual USB to RS232 convertor USB: Two USB2.0 Type A ports I2C: AT24C01B 1K Board EEPROM (8 bit address) QUICC Engine: Connected to DP83849i PHY supply two 10/100M ethernet ports QE UART for RS485 or RS232 PCIE: One mini-PCIE slot Signed-off-by: Michael Johnston <michael.johnston@freescale.com> Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> [yorksun: Fixup include/configs/p1_twr.h] Signed-off-by: York Sun <yorksun@freescale.com>
