path: root/board/freescale/p1023rdb
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc: Fix CamelCase warnings in DDR related codePriyanka Jain
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with embedded acronyms capitalized that trigger the CamelCase warning in checkpatch.pl Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-06-20powerpc/85xx: Add P1023RDB board supportChunhe Lan
P1023RDB Specification: ----------------------- Memory subsystem: 512MB DDR3 (Fixed DDR on board) 64MB NOR flash 128MB NAND flash Ethernet: eTSEC1: Connected to Atheros AR8035 GETH PHY eTSEC2: Connected to Atheros AR8035 GETH PHY PCIe: Three mini-PCIe slots USB: Two USB2.0 Type A ports I2C: AT24C08 8K Board EEPROM (8 bit address) Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
