path: root/board/freescale/p1022ds
2013-05-02powerpc/p1022ds: Add support for NAND and NAND boot using SPLMatthew McClintock
Add defines needed to access NAND, remove second flash bank that is actually connected to NAND. Add nand booting support for P1022DS with hardcoded DDR config using SPL framework from 2011 Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-08powerpc/p1022ds: fix DIU/LBC switching with NAND enabledTimur Tabi
In order for indirect mode on the PIXIS to work properly, both chip selects need to be set to GPCM mode, otherwise writes to the chip select base addresses will not actually post to the local bus -- they'll go to the NAND controller instead. Therefore, we need to set BR0 and BR1 to GPCM mode before switching to indirect mode. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-08powerpc/p1022ds: add support for SPI and SD bootMatthew McClintock
Add TLB mappings, board target options, and configuration items need for SPI/SD boot. Since P1022DS RevB board, the NOR flash have been changed to 16 bit/28bit address flash, therefore, when SDHC/ESPI booting and access to eLBC, the PMUXCR[0~1] must be set to 10b, and PMUXCR[9~10] must be set to 00b for them. Configure the PX_BRDCFG0[0~1] to 10b which is connected to SPI devices as SPI_CS(0:3)_B. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-07-06powerpc/85xx: Add USB device-tree fixup for various platformsramneek mehresh
Add USB device-tree fixup for following platforms: MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-10-27GCC4.6: Squash warnings in diu.cMarek Vasut
diu.c: In function 'diu_set_pixel_clock': diu.c:77: warning: format '%lu' expects type 'long unsigned int', but argument 2 has type 'u32' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-09powerpc/mpc8xxx: Merge entries in DDR speed tableYork Sun
It is not necessary to keep multiple entries for the same setting in DDR speed tables. Merge them for smaller tables. Also restructure the tables for smaller size. Cleanup some typedefs. Enforce strict checking for speed table. If DIMM is running at higher than known speed, try to use the highest speed setting. If rank is unknown, it has to panic. Removed ODT overriding for P2020DS as it is not necessary. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-08-04video: Add SHARP LQ084S3LG01 LCD support on P1022DSTimur Tabi
The SHARP LQ084S3LG01 is a TFT LCD used on the P1022DS (revision "C") board. This device only supports 800x600 resolution, so if that resolution is selected, assume that this is the device. The device is attached to the LVDS port on the P1022DS board. The existing 800x600 entry (for the PDM360NG board) is actually 800x480, so we fix that. To support two different 800x resolutions, the Y-resolution is now passed to fsl_diu_init() and both values are used to pick the proper fb_videomode structure. The data for the 800x600 video mode is originally from Jiang Yutang. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com>
2011-06-09powerpc/p1022ds: set the clock-frequency prop only if the clock is enabledTimur Tabi
The clock-frequency property in an audio codec's device tree node is set to the input clock frequency for that codec. On the Freescale P1022DS board, the input clock is enabled only if the hwconfig 'audclk' option is set. Therefore, the property should only be set in the device tree if the clock is actually enabled. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-29powerpc/85xx: Enable eSPI support on P1022DSJiang Yutang
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-04-20tsec: Convert tsec to use PHY LibAndy Fleming
This converts tsec to use the new PHY Lib. All of the old PHY support is ripped out. The old MDIO driver is split off, and placed in fsl_mdio.c. The initialization is modified to initialize the MDIO driver as well. The powerpc config file is modified to configure PHYLIB if TSEC_ENET is configured. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-10powerpc/85xx: Add support usb2/etsec and tdm/audio pin multiplex on P1022DSJiang Yutang
For soc which have pin multiplex relation, some of them can't enable simultaneously. This patch add environment var 'hwconfig' content defination for them. you can enable some one function by setting environment var 'hwconfig' content and reset board. Detail setting please refer doc/README.p1022ds Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add 36-bit address map support to P1022DSJiang Yutang
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc: Move cpu specific lmb reserve to arch_lmb_reserveKumar Gala
We've been utilizing board_lmb_reserve to reserve the boot page for MP systems. We can just move this into arch_lmb_reserve for 85xx & 86xx systems rather than duplicating in each board port. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04p1022ds: allow for board-specific ngPIXIS functionsTimur Tabi
The ngPIXIS is an FPGA used on the reference boards of most Freescale PowerPC SOCs. Although programming the ngPIXIS is mostly standard on all boards that have it, the P1022DS is unique in that the ngPIXIS needs to be programmed in "indirect" mode whenever the video display (DIU) is active. To support indirect mode, and to make it easier to support other quirks on future reference boards, the low-level ngPIXIS functions are all marked as weak, so that board-specific code can override any of them. We take advantage of this feature on the P1022DS, so that we can properly reset the board when the DIU is active. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Move RESET_VECTOR_ADDRESS into config.hKumar Gala
Rather than defining it config.mk we can set it in config.h and remove config.mk from several boards that don't need it. We mimic what 4xx does and introduce CONFIG_RESET_VECTOR_ADDRESS for config.h to set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/fsl-pci: Add generic code to setup PCIe controllersKumar Gala
Since all the PCIe controllers are connected over SERDES on the SoCs we can utilize is_serdes_configured() to determine if a controller is enabled. After which we can setup the ATMUs and LAWs for the controller in a common fashion and allow board code to specify what the controller is connected to for reporting reasons. We also provide a per controller (rather than all) for some systems that may have special requirements. Finally, we refactor the code used by the P1022DS to utilize the new generic code. Based on patch by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-12-13p1022ds: fix switching of DIU/LBC signalsTimur Tabi
On the P1022, the pins which drive the video display (DIU) are muxed with the local bus controller (LBC), so if the DIU is active, the pins need to be temporarily muxed to LBC whenever accessing NOR flash. The code which handled this transition is checking and changing the wrong bits in PMUXCR. Also add a follow-up read after a write to NOR flash if we're going to mux back to DIU after the write, as described in the P1022 RM. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-10-07p1022ds: add audclk hwconfig setting to enable codec reference clockTimur Tabi
The Freescale P1022DS can use either a 12.288MHz or a 11.2896MHz reference clock for the audio codec, but by default both are disabled. Add a 'audclk' hwconfig option that allows the user to choose which clock he wants. The 12.288MHz clock allows the codec to use sampling rates of 16, 24, 32, 48, 64, and 96KHz. The 11.2896 clock allows 14700, 22050, 29400, 44100, 58800, and 88200Hz. Also configure a pin muxing to select some SSI signals, which will disable I2C1. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-25p1022ds: use weak CFI flash accessors when DIU is enabledTimur Tabi
On the Freescale P1022, the DIU and the LBC share address pins, which means that when the DIU is active (e.g. the console is on the DVI display), NOR flash cannot be accessed. So we use the weak accessor function feature of the CFI flash code to temporarily switch the pin mux from DIU to LBC whenever we want to read or write flash. This has a significant performance penalty, but it's the only way to make it work. This change allows the 'saveenv' command to work when the video display is enabled. Erasing flash and writing to flash (with the 'cp' command) works, but reading from flash (with the 'md' and 'cp' commands) does not. Also, while flash is being written, the video display will be blank. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-09-25p1022ds: add video supportTimur Tabi
Add support for the DIU controller. If CONFIG_VIDEO is defined, then the console will appear on a DVI monitor instead of the serial port. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/85xx: Move p1022ds slot code into board fileKumar Gala
The code to map SERDES configs to slot names is board specific and not chip specific. Thus it should live in board/freescale/p1022ds/ and not in arch/powerpc/cpu/. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc: add support for the Freescale P1022DS reference boardTimur Tabi
Specifics: 1) 36-bit only 2) Booting from NOR flash only 3) Environment stored in NOR flash only 4) No SPI support 5) No DIU support Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
