path: root/board/freescale/p1010rdb
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-01-25powerpc: Drop probecpu() in favour of arch_cpu_init()Simon Glass
To avoid an unnecessary arch-specific call in board_init_f(), rename this function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-24NXP: Introduce board/freescale/common/Kconfig and migrate CHAIN_OF_TRUSTTom Rini
Introduce board/freescale/common/Kconfig so that we have a single place for CONFIG options that are shared between ARM and PowerPC NXP platforms. Cc: York Sun <york.sun@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1010RDB: Remove macros CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PBYork Sun
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-06spi: Move freescale-specific code into a private headerSimon Glass
At present there are two SPI functions only used by freescale which are defined in the spi_flash.h header. One function name matches an existing generic SPL function. Move these into a private header to avoid confusion. Arcturus looks like it does not actually support SPI, so drop the SPI code from that board. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-06-03freescale: Tweak various Makefiles to remove redundancy, fix aestheticsRobert P. J. Day
No intended functional change, just remove redundancies in some Makefiles, and make whitespace aesthetics uniform. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03powerpc/board: SPL: Enable malloc flag in global data.Sumit Garg
For malloc to work in SPL framework enable GD_FLG_FULL_MALLOC_INIT flag in global data after allocating memory using mem_malloc_init. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-28powerpc: p1010rdb: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
The call to pci_eth_init() should not be wrapped with CONFIG_TSEC_ENET. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23driver/ifc: Add 64KB page supportJaiprakash Singh
IFC has two register pages.Till IFC version 1.4 each register page is 4KB each.But IFC ver 2.0 register page size is 64KB each.IFC regiters structure is break into two viz FCM and RUNTIME.FCM(Flash control machine) registers are defined in PAGE0 and controls IFC generic functionality. RUNTIME registers are defined in PAGE1 and controls NAND and GPCM funcinality. FCM and RUNTIME structures defination is common for IFC version 1.4 and 2.0. Signed-off-by: Jaiprakash Singh <b44839@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
With this, fixup a trivial build error of get_effective_memsize needing to be updated in the new board/freescale/p1010rdb/spl.c Signed-off-by: Tom Rini <trini@ti.com>
2014-02-24powerpc: p1010rdb: Enable p1010rdb to start from NAND/SD/SPI flash with SPLYing Zhang
In the previous patches, we introduced the SPL/TPL fraamework. For SD/SPI flash booting way, we introduce the SPL to enable a loader stub. The SPL was loaded by the code from the internal on-chip ROM. The SPL initializes the DDR according to the SPD and loads the final uboot image into DDR, then jump to the DDR to begin execution. For NAND booting way, the nand SPL has size limitation on some board(e.g. P1010RDB), it can not be more than 8KB, we can call it "minimal SPL", So the dynamic DDR driver doesn't fit into this minimum SPL. We added the TPL that is loaded by the the minimal SPL. The TPL initializes the DDR according to the SPD and loads the final uboot image into DDR,then jump to the DDR to begin execution. This patch enabled SPL/TPL for P1010RDB to support starting from NAND/SD/SPI flash with SPL framework and initializing the DDR according to SPD in the SPL/TPL. Because the minimal SPL load the TPL to L2 SRAM and the jump to the L2 SRAM to execute, so the section .resetvec is no longer needed. Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-02board/freescale:Remove use of CONFIG_SPL_NAND_MINIMALPrabhakar Kushwaha
CONFIG_SPL_NAND_MINIMAL should not be used as it was defined for temporary review purpose. So, use CONFIG_SPL_NAND_BOOT config. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-25Driver/IFC: Move Freescale IFC driver to a common driverYork Sun
Freescale IFC controller has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the driver to driver/misc and fix the header file includes. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/p1010rdb: update readme for p1010rdb-pa and p1010rdb-pbShengzhou Liu
- Remove duplicate doc/README.p1010rdb - Rename README to README.P1010RDB-PA - Add new README.P1010RDB-PB P1010RDB-PB is a variation of previous P1010RDB-PA board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-10-16powerpc/p1010rdb: add p1010rdb-pb support with updating p1010rdb-paShengzhou Liu
- Rename old P1010RDB board as P1010RDB-PA. - Add support for new P1010RDB-PB board. - Some optimization. For more details, see board/freescale/p1010rdb/README. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: fix conflicts in boards.cfg] Acked-by: York Sun <yorksun@freescale.com>
2013-10-16board/p1010rdb: add pin mux and sdhc support in any bootShengzhou Liu
Since pins multiplexing, SDHC shares signals with IFC, with this patch: To enable SDHC in case of NOR/NAND/SPI boot a) For temporary use case in runtime without reboot system run 'mux sdhc' in u-boot to validate SDHC with invalidating IFC. b) For long-term use case set 'esdhc' in hwconfig and save it. To enable IFC in case of SD boot a) For temporary use case in runtime without reboot system run 'mux ifc' in u-boot to validate IFC with invalidating SDHC. b) For long-term use case set 'ifc' in hwconfig and save it. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-10-16powerpc/p1010rdb: remove unused cpld_showShengzhou Liu
Function cpld_show() was for debug and not called, so clean it. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-10-16powerpc: Fix CamelCase warnings in DDR related codePriyanka Jain
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with embedded acronyms capitalized that trigger the CamelCase warning in checkpatch.pl Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-08-20powerpc/p1010rdb: fix calculating ddr_freq_mhzShengzhou Liu
There was a bug for calculating ddr_freq_mhz, it should be divided by 1000000 rather than 0x1000000. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/mpc8xxx: Add memory reset controlYork Sun
JEDEC spec requires the clocks to be stable before deasserting reset signal for RDIMMs. Clocks start when any chip select is enabled and clock control register is set. This patch also adds the interface to toggle memory reset signal if needed by the boards. Signed-off-by: York Sun <yorksun@freescale.com>
2013-06-20board/p1010rdb: Fix PCIe TLB creation on CONFIG_PCI definePrabhakar Kushwaha
PCIe TLB should be created with CONFIG_PCI defined Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:Fix "boot page TLB" entry size for NAND SPLPrabhakar Kushwaha
e500v2 processor does not support 8K page size TLB entries. So create new TLB entry only during NAND SPL boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/p1010rdb:Add NAND boot support using new SPL formatPrabhakar Kushwaha
- defines constants - Add spl_minimal.c to initialise DDR - update TLB entries as per NAND boot - remove nand_spl support for P1010RDB Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/p1010rdb: Change flexcan compatible stringShengzhou Liu
Change flexcan compatible string from "fsl,flexcan-v1.0" to "fsl,p1010-flexcan" to match the device tree. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-02-04ppc: Move lbc_clk and cpu to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Update for bsc9132qds.c, b4860qds.c] Signed-off-by: Tom Rini <trini@ti.com>
2012-08-23p1010rdb: fix ddr values for p1014rdb (setting bus width to 16bit)Matthew McClintock
There was an extra 0 in front of the value we were using to mask, remove it to improve the code. Also fix the value written to ddr_sdram_cfg to set the bus width properly to 16 bits Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-22Minor Coding Style Cleanup.Wolfgang Denk
2012-07-10Minor Coding Style cleanupWolfgang Denk
2012-07-06powerpc/mpc85xx: Ignore E bit for SVR_SOC_VER()York Sun
We don't care E bit of SVR in most cases. Clear E bit for SVR_SOC_VER(). This will simplify the coding. Use IS_E_PROCESSOR() to identify SoC with encryption. Remove all _E entries from SVR list and CPU list. Signed-off-by: York Sun <yorksun@freescale.com>
2012-07-06powerpc/p1010rdb: add readme document for p1010rdbShengzhou Liu
2012-07-06powerpc/p1010rdb: update mux config of p1010rdb boardShengzhou Liu
On p1010rdb some signals are muxed for tdm/can/uart/flash. If we don't set fsl_p1010mux:tdm_can to "can" or "tdm" explicitly, defaultly we keep spi chip selection to spi-flash instead of to tdm/slic and disable uart1 when not using flexcan, as well disable sdhc. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-24powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boardsYork Sun
P1010RDB and p1_pc_rdb_pc has incorrect configuration for CONFIG_DDR_RAW_TIMING. It should be CONFIG_SYS_DDR_RAW_TIMING. Incorrect setting causes DDR failure in case of SPD absent. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-11-08powerpc/85xx: Make inclusion of USB device fixup conditionalRamneek Mehresh
Include call to usb device-fixup only when CONFIG_HAS_FSL_DR_USB is defined for the platform - P1020RDB, P1010RDB, P1020-PC Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
