path: root/board/freescale/mx7ulp_evk
2017-03-17imx: imx7ulp: add EVK board supportPeng Fan
Add EVK board support. Add the evk dts file. LOG: U-Boot 2017.03-rc2-00038-gab86c1d (Feb 22 2017 - 15:59:58 +0800) CPU: Freescale i.MX7ULP rev1.0 at 500 MHz Reset cause: POR Boot mode: Dual boot Model: NXP i.MX7ULP EVK DRAM: 1 GiB MMC: FSL_SDHC: 0 In: serial@402D0000 Out: serial@402D0000 Err: serial@402D0000 Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
