path: root/board/freescale/mx6sabresd
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-12mx6sabresd: Include <usb/ehci-ci.h> header fileDiego Dorta
When compiling with W=1 the following warning is observed: board/freescale/mx6sabresd/mx6sabresd.c:586:5: warning: no previous prototype for ‘board_ehci_hcd_init’ [-Wmissing-prototypes] int board_ehci_hcd_init(int port) Remove this warning by including <usb/ehci-ci.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
2017-10-12mx6sabresd: Include <asm/mach-imx/spi.h> header fileDiego Dorta
When compiling with W=1 the following warning is observed: board/freescale/mx6sabresd/mx6sabresd.c:680:5: warning: no previous prototype for ‘board_spi_cs_gpio’ [-Wmissing-prototypes] int board_spi_cs_gpio(unsigned bus, unsigned cs) Remove this warning by including <asm/mach-imx/spi.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
2017-10-12imx: Include <input.h> header fileDiego Dorta
When building with W=1 errors like the one below is seen: board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning: no previous prototype for ‘overwrite_console’ [-Wmissing-prototypes] int overwrite_console(void) Fix the build warnings by including <input.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-12mx6sabresd: Avoid calling setup_display() from SPL codeFabio Estevam
There is no need call setup_display() from SPL code, so move it to board_init(), which executes only in U-Boot proper. Reported-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-16Merge git://www.denx.de/git/u-boot-imxTom Rini
Update pfla02 for setenv changes and PHYLIB/etc migration to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16mx6sabresd: Fix IOMUXC_GPR6 and IOMUXC_GPR7 valuesBreno Lima
The IPU AXI QoS for the i.MX6QP and i.MX6DP processors have to be set as commented in the code: /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ Set IOMUXC_GPR6 and IOMUXC_GPR7 to 0x77177717 instead of 0x007F007F. Signed-off-by: Breno Lima <breno.lima@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-05-31mx6sabresd: Update to SPL only modeFabio Estevam
mx6sabresd only supports SPL mode now, so update the README file accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-05-31mx6sabresd: Update the config fileFabio Estevam
Only configs/mx6sabresd_defconfig is supported now, so update the MAINTAINERS file accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-05-18mx6sabresd: Remove non-SPL targetsFabio Estevam
Now that mx6sabresd_spl_defconfig can be used to boot all mx6sabresd variants, the non-SPL targets can be safely removed. Signed-off-by: Fabio Estevam <fabio.estvam@nxp.com>
2017-05-18mx6sabresd: Add SPL support for the mx6dl variantFabio Estevam
Add support for the mx6dlsabresd board in SPL. Retrieved the DCD table from: board/freescale/mx6sabresd/mx6dlsabresd.cfg (NXP U-Boot branch imx_v2015.04_4.1.15_1.0.0_ga) Flashed SPL and u-boot.img to an SD card and could successfully boot it on mx6q, mx6qp and mx6dl sabresd boards. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-18mx6sabresd: Prepare for supporting MX6DLFabio Estevam
Currently only MX6Q/QP sabresd boards are supported in SPL. In order to also support MX6DL we need to convert to using IOMUX_PADS and SETUP_IOMUX_PADS macros. Other than that move the <asm/arch/mx6-ddr.h> header inclusion to the SPL code block in order to avoid build error. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-12mx6sabresd: README: Add eMMC boot configurationBreno Lima
Explain how to flash the eMMC and how to boot from it. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-11-06mx6sabresd: Make Ethernet functional againFabio Estevam
Since commit ce412b79e7255770 ("drivers: net: phy: atheros: add separate config for AR8031") ethernet does not work on mx6sabresd. This commit correctly assigns ar8031_config() as the configuration function for AR8031 in the same way as done in the Linux kernel. However, on mx6sabresd design we need some additional configuration, such as enabling the 125 MHz AR8031 output that needs to be done in the board file. This also aligns with the same method that the kernel performs the AR8031 fixup in arch/arm/mach-imx/mach-imx6q.c. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-17mx6sabresd: Add README fileDiego Dorta
Add a README to explain the steps for booting mx6sabresd in different ways: 1. Booting via Normal U-Boot (u-boot.imx) 2. Booting via SPL (SPL and u-boot.img) 3. Booting via Falcon mode (SPL launches the kernel directly) Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
2016-10-17mx6sabresd: Add Falcon mode supportDiego Dorta
Allow i.MX6Q Sabre SD to load the kernel and dtb via SPL in Falcon mode. Based on the Falcon mode code for MX6 Gateworks Ventana board. Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
2016-10-04mx6sabresd: Make SPL DDR configuration to match the DCD tableFabio Estevam
When using SPL on i.mx6 we frequently notice some DDR initialization mismatches between the SPL code and the non-SPL code. This causes stability issues like the ones reported at 7dbda25ecd6d7c ("mx6ul_14x14_evk: Pass refsel and refr fields to avoid hang") and also: http://lists.denx.de/pipermail/u-boot/2016-September/266355.html . As the non-SPL code have been tested for long time and proves to be reliable, let's configure the DDR in the exact same way as the non-SPL case. The idea is simple: just use the DCD table and write directly to the DDR registers. Retrieved the DCD tables from: board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg and board/freescale/mx6sabresd/mx6qp.cfg (NXP U-Boot branch imx_v2015.04_4.1.15_1.0.0_ga) This method makes it easier for people converting from non-SPL to SPL code. Other benefit is that the SPL binary size is reduced from 44 kB to 39.9 kB. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-06-18mx6sabresd: Allow LVDS backlight to be functional after a kernel rebootMarco Franchi
Currently the LVDS backlight does not work in U-Boot after a “reboot” comand in the kernel. This problem occurs because the kernel uses this pin in PWM mode and U-Boot does not configure the backlight pin as GPIO functionality. So fix the problem by explicitly configuring the backlight pin as GPIO in U-Boot. Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-05-24board: mx6sabresd/auto: use simpler runtime cpu dection macrosPeng Fan
Use simpler runtime cpu dection macros. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-03mx6sabresd: Remove unneeded enable_lvds() functionFabio Estevam
enable_lvds() function only set bits IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT and IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT, but these bits were already set previously inside setup_display(). We can safely remove enable_lvds() then. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-03-25mx6sabresd: Use VESA 1024x768 timingsFabio Estevam
VESA 1024x768 results in much more accurate timings. Based on the patch from Soeren Moch for the tbs2910 board. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-04imx: mx6: implement board_mmc_get_env_devPeng Fan
Implement board_mmc_get_env_dev for the boards. Following is examples: SD1/SD2/SD3: return devno; SD2/SD3: return devno - 1; SD2/SD4: if (devno == 2), return dev - 2; return dev - 1; Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-02-02imx: MX6DQ{P}/DL:SABRESD Fix bmode eMMC failureYe Li
The BOOTCFG value used by bmode for SABRESD eMMC boot are actually for SD card. Fixed the value to correct one. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-01-11MAINTAINERS/mailmap: Update my email addressFabio Estevam
Update my email address to the NXP account. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-01-07mx6sabresd: Simplify the Ethernet PHY configurationFabio Estevam
As per the AR8031 datasheet: "For a reliable power on reset, suggest to keep asserting the reset low long enough (10ms) to ensure the clock is stable and clock-to-reset 1ms requirement is satisfied." So do as suggested and also add a 100us delay after deasserting the reset line to guarantee that the PHY ID can be read correctly and the Atheros 8031 PHY driver can be loaded automatically. This results in a simpler code. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-11-12mx6sabresd: Remove empty reset_cpu()Fabio Estevam
There is really no need to provide an empty reset_cpu() implementation, so just remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-10-30imx: mx6sabresd: add i.MX6DQP Sabresd supportPeng Fan
Add i.MX6DQP-Sabresd board support: 1. set fdt_file according to board_rev which is set at runtime. 2. Add mx6dqp_ddr_ioregs and calibration value for this board. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02imx: mx6: ddr init MMDC according to ddr_typePeng Fan
To i.MX6, DDR3 and LPDDR2 is supported, so rename function mx6_dram_cfg to mx6_ddr3_cfg and the original mx6_dram_cfg function only is a wrapper. The new reimplemented function mx6_dram_cfg only invokes mx6_ddr3_cfg when ddr_type is for DDR3. Later we can use ddr_type to initialize MMDC for LPDDR2. Initialize ddr_type for different boards which enable SPL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefan Roese <sr@denx.de>
2015-08-02imx: mx6sabresd/sabreauto runtime setting fdt_filePeng Fan
Detect the SOC and board variant at runtime and change the dtb name, but not hardcoding the fdt_file env variable. Take the following patch as a reference. Íd58699b157df75f1aa0b363ea9c21add21a0c "mx6cuboxi: Load the correct 'fdtfile' variable" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-26mx6sabresd: Use 'int' for return valuesFabio Estevam
The variable 'ret' is used to store the value returned by pfuze_mode_init(), so it should of type 'int' instead of 'unsigned int' in order to correctly handle negative numbers. Fix the variable type. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-04-22mx6sabresd: Remove uneeded ifdefFabio Estevam
RTT_NOM_120OHM is not defined, so remove its ifdef. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-04-22mx6sabresd: Fix SPL memory descriptionFabio Estevam
mx6sabresd has four MT41K128M16JT-125 chips. Each memory has 16-bit bus and 2GiB, so fix the width and density fields accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-02-11imx:mx6 set normal APS and standby PFM modePeng Fan
To normal mode, use APS switching mode. To standy mode, use PFM switching mode. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-12-19imx:mx6sabresd add board level support for usbPeng Fan
Add pinmux settings, implement board_ehci_hcd_init and board_ehci_power Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2014-11-20imx: mx6sabresd: Use the pfuze common init functionYe.Li
Modify the pfuze init for mx6sabresd to use the shared "pfuze_common_init" function. And move this initialization to power_init_board. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20mx6sabresd: Access SRC_SBMR1 register via structureFabio Estevam
In U-boot it is preferred to access the register via structure pointer, so convert it such style. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6sabresd: Add mx6sabresd_spl_defconfig to MAINTAINERS entryFabio Estevam
Let's add mx6sabresd_spl_defconfig entry into MAINTAINERS, so that we avoid getting a warning that the mx6sabresd_spl is not maintained. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6sabresd: State that only mx6q is supported in SPLFabio Estevam
Make clear that current SPL code only supports the mx6q variant. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-20mx6sabresd: Move the DCD settings to spl codeFabio Estevam
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR. Move the configuration to the spl code. CCM_CCOSR setting is no longer required to get audio functionality in the kernel, so remove such setting. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13mx6sabresd: Staticize when possibleFabio Estevam
Annotate 'static' when appropriate for the variables used locally. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
