path: root/board/freescale/mx6qsabrelite
2012-02-27i.mx6q: mx6qsabrelite: Update the network configurationTroy Kisky
Define CONFIG_PHY_MICREL, and minimize the tx clock delay. There is an issue with 1000 baseTx mode on early revs of the SabreLite boards. The center tap pin 9 of the mag RJ45 USB combo was connected to the 3.3 filtered supply. Letting this pin float solved the problem. Symptoms of the problem were packets with many extra zeroes tacked on the end, and random bit flips causing a high rate of CRC errors. 10/100 baseTx worked fine on all revs. To disable 1000 baseTx for these boards, simply define the environment variable disable_giga. ie. setenv disable_giga 1 Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27mx6q: mx6qsabrelite: Provide default serial flash bus and chip-selectEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Add ECSPI support to the Sabrelite platformEric Nelson
2012-02-12i.mx6q: mx6qsabrelite: Add the ethernet function supportJason Liu
Signed-off-by: Jason Liu <jason.hui@linaro.org> Signed-off-by: Eric Miao <eric.miao@linaro.org> CC: Jason Liu <jason.hui@linaro.org> CC: Stefano Babic <sbabic@denx.de>
2012-02-12i.mx6q: mx6qsabrelite: Setup uart1 pinmuxTroy Kisky
This allows the Linux kernel to use UART1 before pinmux support is added for UART1 Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Jason Liu <jason.hui@linaro.org> CC: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-01-16i.mx: i.mx6q: add the initial support for i.mx6q Sabre Lite boardJason Liu
Add the initial support for Freescale i.MX6Q Sabre Lite board Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Jason Liu <jason.hui@linaro.org> CC: Eric Nelson <eric.nelson@boundarydevices.com>
