path: root/board/freescale/mx53smd
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-05imx: mx53smd: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-01-22imximage.cfg: run files through C preprocessorTroy Kisky
The '#' used as comments in the files cause the preprocessor trouble, so change to /* */. The mkimage command which uses this preprocessor output was moved to arch/arm/imx-common/Makefile .gitignore was updated to ignore .cfgtmp files. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-10-16mxc: Fix SDHC multi-instance clockBenoît Thébaudeau
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not suitable for the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). This patch fixes this issue by adding a configuration field for the SDHC input clock frequency. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Andy Fleming <afleming@gmail.com>
2012-09-01fsl_esdhc: Remove cache snooping for i.MXBenoît Thébaudeau
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() is used on i.MX, like in arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init(). Since no_snoop was only used on i.MX, get rid of it BTW. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com>
2012-09-01mx5:Use IMX_GPIO_NR macroAshok Kumar Reddy
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
2012-07-07mx53smd: Remove unused SOBJSFabio Estevam
There is no .S file in this directory, so just remove SOBJS. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16MX53: DDR: Fix ZQHWCTRL field TZQ_CSTroy Kisky
Currently, board files are setting this field to 0x01 which the manual says is a reserved value. Change to use the default of 0x02 - 128 cycles. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx53smd: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
Use gpio_direction_input prior to gpio_get_value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-01-08mmc: Change board_mmc_getcd() function prototype.Thierry Reding
The new API no longer uses the extra cd parameter that was used to store the card presence state. Instead, this information is returned via the function's return value. board_mmc_getcd() returns -1 to indicate that no card-detection mechanism is implemented; 0 indicates that no card is present and 1 is returned if it was detected that a card is present. The rationale for this change can be found in the following email thread: http://lists.denx.de/pipermail/u-boot/2011-November/110180.html In summary, the old API was not consistent with the rest of the MMC API which always passes a struct mmc as the first parameter. Furthermore the cd parameter was used to mean "card absence" in some implementations and "card presence" in others. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-12-06mx53smd: Configure the pins as GPIOs prior to using gpio_get_valueFabio Estevam
Configure the pins as GPIO prior to using gpio_get_value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-04mx53smd: Remove unused get_board_rev functionFabio Estevam
No board information is passed for MX53SMD, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx53smd: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-04MX5: mx53smd: make use of GPIO frameworkStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-04mx53: ddr3: Update DD3 initializationFabio Estevam
Updated mx53 ddr3 script in order to align with the latest Freescale version from July 8, 2011: -change ESDREF[REF_SEL]=01 (for 32KHz), from incorrect setting of 00 (64KHz) -change DDR3 MR0 write to "setmem /32 0x63fd901c = 0x052080b0" from "0x092080b0". This changes write recovery from 8 clocks to 6 clocks (in line with ESDCFG1[tWR]) Signed-off-by: Lily Zhang <r58066@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
