path: root/board/freescale/mx51evk
2010-10-28MX5:use common u-boot.lds of cpu layerJason Liu
Remove u-boot.lds from mx5 and use the common u-boot.lds of cpu layer. This patch also fix the building errors: arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start' arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end' arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start' Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-19Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
Conflicts: board/logicpd/imx31_litekit/config.mk boards.cfg Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18MX5: rename mx51 to mx5Jason Liu
Rename mx51 to mx5 in order to support more mx51 like-style SOCs such as MX53 and the followings. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-14mx51evk: add u-boot.imx to ALL targetLoic Minier
Signed-off-by: Loic Minier <loic.minier@linaro.org> CC: stefano babic <sbabic@denx.de>
2010-09-29MX51: Drop unused header file for mx51evkStefano Babic
As stated in 272017853339f5b9685f9488bdaf5405812d12a4, the mx51evk has not CPLD and all references must be removed. This patch drop a .h file that still remains in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-05-05Add SPI support to mx51evk boardStefano Babic
The patch adds SPI devices to the mx51evk board. The MC13892 chip (PMIC) is supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-05-05MX51evk: Removed warningsStefano Babic
Changes reflect modifications in the fsl_esdhc driver (the clk_enable field war removed in the configuration structure). Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30mx51evk: correct list of possible BOOT_FROM valuesStefano Babic
2010-04-30MX51EVK: Remove CPLD related codeFabio Estevam
There is no CPLD on MX51EVK board, so remove CPLD related function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07MX51: removed warnings for the mx51evkStefano Babic
The patch removes warnings at compile time and provides some cleanup code: - Removed comment on NAND (not yet supported) from lowlevel_init.S - Removed NFMS bit definition from imx-regs.h The bit is only related to MX.25/35 and can lead to confusion - Moved is_soc_rev() to soc specific code (removed from mx51evk.c) Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07Add initial support for Freescale mx51evk boardStefano Babic
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fred Fan <fanyefeng@gmail.com>
