path: root/board/freescale/mx51evk
2010-05-05MX51evk: Removed warningsStefano Babic
Changes reflect modifications in the fsl_esdhc driver (the clk_enable field war removed in the configuration structure). Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30mx51evk: correct list of possible BOOT_FROM valuesStefano Babic
2010-04-30MX51EVK: Remove CPLD related codeFabio Estevam
There is no CPLD on MX51EVK board, so remove CPLD related function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07MX51: removed warnings for the mx51evkStefano Babic
The patch removes warnings at compile time and provides some cleanup code: - Removed comment on NAND (not yet supported) from lowlevel_init.S - Removed NFMS bit definition from imx-regs.h The bit is only related to MX.25/35 and can lead to confusion - Moved is_soc_rev() to soc specific code (removed from mx51evk.c) Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07Add initial support for Freescale mx51evk boardStefano Babic
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fred Fan <fanyefeng@gmail.com>
