path: root/board/freescale/mx51evk
2013-11-27mx51evk: Fix pmic_init() argumentFabio Estevam
On mx51evk board the PMIC is connected via SPI interface, so it does not make sense to pass I2C_PMIC into the pmic_init() interface. Pass the SPI bus number via CONFIG_FSL_PMIC_BUS option instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-05imx: mx51evk: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior, except for older silicon revisions for which support is removed. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-01-22imximage.cfg: run files through C preprocessorTroy Kisky
The '#' used as comments in the files cause the preprocessor trouble, so change to /* */. The mkimage command which uses this preprocessor output was moved to arch/arm/imx-common/Makefile .gitignore was updated to ignore .cfgtmp files. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-13mx51evk: Add DVI output supportFabio Estevam
Add DVI output support and make it the default video output. Currently the CLAA WVGA panel is supported, but this panel has to be purchased separately, so using the DVI output as the default would allow more people to try the splash screen feature on a mx51evk. If someone still wants to use the CLAA WVGA, just set the panel variable as: set panel claa Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-19Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2012-11-14mx51evk: Fix build error when CONFIG_VIDEO is disabledVikram Narayanan
The inclusion of LCD patch into mx51evk breaks the build when CONFIG_VIDEO is disabled. Fix this by splitting the video related stuff to a new file. Also rename the function lcd_iomux to setup_iomux_lcd to make the namings aligned with the other iomux functions. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-16i.MX: ipufb: add const to fb_videomode declarationsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-16mxc: Fix SDHC multi-instance clockBenoît Thébaudeau
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not suitable for the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). This patch fixes this issue by adding a configuration field for the SDHC input clock frequency. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Andy Fleming <afleming@gmail.com>
2012-09-23mx51evk: Add CONFIG_REVISION_TAGBenoît Thébaudeau
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information. If this data is not present, the kernel misconfigures the TZIC, which results in the timer interrupt handler never being called, so the kernel deadlocks while calibrating its delay. Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01fsl_esdhc: Remove cache snooping for i.MXBenoît Thébaudeau
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() is used on i.MX, like in arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init(). Since no_snoop was only used on i.MX, get rid of it BTW. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com>
2012-09-01mx5:Use IMX_GPIO_NR macroAshok Kumar Reddy
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
2012-09-01mx51evk: Use IMX_GPIO_NR macroFabio Estevam
2012-09-01mx51evk: do not overwrite the consoleFabio Estevam
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-07mx51evk: Remove unused SOBJSFabio Estevam
There is no .S file in this directory, so just remove SOBJS. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-25mx5: Rename mx51_fb_init()Fabio Estevam
The ipuv3 driver is currently only used on mx51, but it can be extended to work on mx53 and mx6 as well. Rename mx51_fb_init(), so that it can be used by other SoCs. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-05-25mx51evk: Add LCD supportFabio Estevam
Add support for CLAA07LC0ACW LCD that connects to the mx51evk board. Configure the board to show the Linux logo on the LCD. Also increase the size of CONFIG_SYS_MALLOC_LEN variable to take into account the framebuffer usage. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-02-27mx51evk: Use gpio_direction_input prior to gpio_get_valueFabio Estevam
Use gpio_direction_input prior to gpio_get_value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-01-08mmc: Change board_mmc_getcd() function prototype.Thierry Reding
The new API no longer uses the extra cd parameter that was used to store the card presence state. Instead, this information is returned via the function's return value. board_mmc_getcd() returns -1 to indicate that no card-detection mechanism is implemented; 0 indicates that no card is present and 1 is returned if it was detected that a card is present. The rationale for this change can be found in the following email thread: http://lists.denx.de/pipermail/u-boot/2011-November/110180.html In summary, the old API was not consistent with the rest of the MMC API which always passes a struct mmc as the first parameter. Furthermore the cd parameter was used to mean "card absence" in some implementations and "card presence" in others. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-12-19Fix building for mx51evk boardAnatolij Gustschin
Fix: mx51evk.c:206:6: error: conflicting types for 'board_ehci_hcd_init' /u-boot/include/usb/ehci-fsl.h:254:5: note: previous declaration of 'board_ehci_hcd_init' was here We also fix board_ehci_hcd_init() for mx53loco board. Building for mx53loco worked since <usb/ehci-fsl.h> is not included here. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-11USB: mx51evk: add end enable USB host support on port 1Wolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-06mx51evk: Configure the pins as GPIOs prior to using gpio_get_valueFabio Estevam
Configure the pins as GPIO prior to using gpio_get_value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx51evk: Remove unused get_board_rev functionFabio Estevam
No board information is passed for MX51EVK, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx51evk: Use GPIO API for configuring the IOMUXFabio Estevam
GPIO API provides mxc_request_iomux function for setting the IOMUX mode. Use this function instead of directly writing to the IOMUX register. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27MX5: mx51evk: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-30mx51evk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-04MX5: mx51evk: make use of GPIO frameworkStefano Babic
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-05-23mx5: board: code clean up for checkboard codeJason Liu
The boot cause code has been factor out to soc common code,we need drop the part from the board support code This patch also remove the redundant cpu version print Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-04-27MX51: drop config.mk from mx51evkStefano Babic
The config.mk file in board directory is now obsolete and should be removed. Add option for the IMX image into boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02MX51EVK: Use SWx macros in PMIC initMarek Vasut
2011-02-02MX51EVK: UART does not print out the early informationLiu Hui-R64343
The early bootup information is not print out due to the UART pin iomux not set up correctly before board_init Add the board_early_init_f function and enable the CONFIG_BOARD_EARLY_INIT_F. Move the UART pin setting from board_init to board_early_init_f function. This patch also move the FEC pin iomux setup to the board_early_init_f. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-28mx51evk: support new relocation schemeShawn Guo
This patch is to fix build breakage and support new relocation scheme for mx51evk. - Correct IRAM base address and add size definition The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than 0x1FFE8000 which is for older revision. - Include imx-regs.h in mx51evk.h Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be referred to. - Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE They are used to define init RAM layout. - Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been buried by Wolfgang's commit below 25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: Fix 2 hours reset issueShawn Guo
The mx51evk u-boot has an issue that system will get reset every 2 hours. MC13892 has an inside charge timer which expires in 120 minutes. If ICHRG and CHGAUTOB are not set properly, this timer expiration will get system power recycled. Since mx51evk has no Li-Ion battery on board, the patch sets ICHRG in externally powered mode and sets CHGAUTOB bit to avoid automatic charging, so that system will not get reset by this timer expiration. The patch also corrects the bit field definition of register 48 (Charger 0) per latest MC13892 Reference Manual. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28MX5:use common u-boot.lds of cpu layerJason Liu
Remove u-boot.lds from mx5 and use the common u-boot.lds of cpu layer. This patch also fix the building errors: arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start' arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end' arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start' Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-19Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
Conflicts: board/logicpd/imx31_litekit/config.mk boards.cfg Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18MX5: rename mx51 to mx5Jason Liu
Rename mx51 to mx5 in order to support more mx51 like-style SOCs such as MX53 and the followings. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-14mx51evk: add u-boot.imx to ALL targetLoic Minier
Signed-off-by: Loic Minier <loic.minier@linaro.org> CC: stefano babic <sbabic@denx.de>
2010-09-29MX51: Drop unused header file for mx51evkStefano Babic
As stated in 272017853339f5b9685f9488bdaf5405812d12a4, the mx51evk has not CPLD and all references must be removed. This patch drop a .h file that still remains in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de>
