path: root/board/freescale/mx35pdk
2013-12-17imx: Explicitly pass the I2C bus number in pmic_init()Fabio Estevam
The pmic_init() function has the I2C or SPI bus number that is connected to the PMIC. Instead of passing I2C_PMIC, explicitly pass the I2C bus number via I2C_x definition. The motivation for doing this is to avoid people just doing a copy and paste of I2C_PMIC into their board file when another I2C bus is actually used to interface to their PMIC. This also makes more obvious which is the I2C bus connected to the PMIC, without having to search in the source code for the meaning of the 'I2C_PMIC' number. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-09-27mx35pdk: Fix error handling in board_late_init()Fabio Estevam
If smc911x_initialize() fails we should return the error immediately. While at it, also check the error from cpu_eth_init(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-06imx: mx35pdk: Fix MUX2_CTR GPIOBenoît Thébaudeau
MUX2_CTR is on GPIO1[5], not GPIO2[5], and it needs to be set high in order to connect the FEC. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-05imx: mx35pdk: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-05imx: mx35pdk: Fix WDOG_RST iomux functionBenoît Thébaudeau
The signal connected from this pin to the PMIC is WDOG_B, i.e. ALT0 mode, not ALT1 (which even corresponds to nothing). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-01-05mx35pdk:Use IMX_GPIO_NR macroAshok
Use IMX_GPO_NR macro Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-11-16mx35pdk: Add support for OTGBenoît Thébaudeau
Add support for the OTG port on the mx35pdk Personality board. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Stefano Babic <sbabic@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-16mxc: Fix SDHC multi-instance clockBenoît Thébaudeau
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not suitable for the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). This patch fixes this issue by adding a configuration field for the SDHC input clock frequency. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Andy Fleming <afleming@gmail.com>
2012-10-16mx35: Clean up lowlevel_initBenoît Thébaudeau
Clean up mx35 lowlevel_init: - Indent with tabs. - Fix comments. - Use defined values instead of literal constants. - Use defined macros instead of duplicating code. - Use macro parameters with default values instead of #define'd configs. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-17mx35pdk: README: Remove NAND referencesFabio Estevam
Booting from NAND is currently not supported, so remove its references. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-10MX35: mx35pdk: add support for MMCStefano Babic
Add support for SD card and change the default environment due to increased u-boot size. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-01mx35: Fix typo on EDIOBenoît Thébaudeau
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-04-16MX35: mx35pdk: wrong board revisionStefano Babic
The board revision is detected accessing to the pmic, that is not available before relocation (I2C). This generates the following error: CPU: Freescale i.MX35 rev 2.0 at 532 MHz. Reset cause: WDOG <reg num> = 7 is invalid. Should be less than 0 Board: MX35 PDK 1.0 The revision number is wrong, as a default value is printed (tested on a mx35pdk Rev. 2.0). Move the output in the board_late_init(), when pmic can be accessed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-02-27mx35pdk: Remove duplicate CPU revision and reset cause informationFabio Estevam
MX35PDK board does not need to print CPU revision and reset cause in board file because this is printed by common code when CONFIG_DISPLAY_CPUINFO is selected Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03MX35: added ESDC structure to imx-regsStefano Babic
The structure and PLL defines are added to the imx-regs.h file and dropped from board header files. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27MX35: mx35pdk: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04MX35: mx35pdk: make use of GPIO frameworkStefano Babic
2011-09-04MX35: MX35PDK: support additional RAM on CSD1Stefano Babic
Modules on mx35pdk have additional 128MB memory connected to CSD1. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02Add support for Freescale's mx35pdk board.Stefano Babic
The patch adds suupport for the Freescale's mx35pdk board (known as well as mx35_3stack). The board boots from the NOR flash. Following devices are supported: - two ethernet devices (FEC and SMC911x on debug board) - I2C - PMIC (MC13892) via I2C interface - UART - NOR flash (64MB) - NAND flash (2GB) - basic access to mc9sdz60 registers via I2C interface Signed-off-by: Stefano Babic <sbabic@denx.de>
