path: root/board/freescale/mx31pdk
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-05-11MX31: mx31pdk: Add watchdog supportFabio Estevam
2011-04-27MX31: mx31pdk: Make the board name simpler.Fabio Estevam
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-21mx31pdk: Make the full boot log visibleFabio Estevam
Use board_early_init_f so that the full boot log output can be displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-02-21mx31pdk: Use the new relocation schemeFabio Estevam
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-07-06MX31: Add NAND SPL boot support to i.MX31 PDK board.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-07-06MX31: Add basic support for Freescale i.MX31 PDK board.Magnus Lilja
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board). This patch assumes that some other program performs the actual NAND boot. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabioestevam@yahoo.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
