path: root/board/freescale/mx31ads
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-13mx31: move freescale's mx31 boards to vendor board dirJean-Christophe PLAGNIOL-VILLARD
