This platform has been marked as orphaned since September 2013, remove.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
The "S: Orphan" in MAINTAINERS means that the maintainer in the
"M:" field is unreachable (i.e. the email address is not working).
(Refer to the definition of "Orphan" adopted in U-Boot
in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b,
"boards.cfg: move boards with invalid emails to Orphan")
For patch files adding global changes, scripts/get_maintainer.pl
adds bunch of such invalid email addresses, which results in
tons of annoying bounce emails.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '
/^M:[[:blank:]]/ {
N
/S:[[:blank:]]Orphan/s/^/#/
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Correct the binary output so that image_binary_size is really at the
end of the image.
Exception handling is basically identical for all ARM targets.
Factorize it out of the various start.S files and into a
single vectors.S file, and adjust linker scripts accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This prevents references to _end from generating absolute
relocation records.
This change is binary invariant for ARM targets.
arch/arm/cpu/armv7/rmobile/Makefile
doc/README.scrapyard
Needed manual fix:
arch/arm/cpu/armv7/omap-common/Makefile
board/compulab/cm_t335/u-boot.lds
Current LDS files /DISCARD/ a lot of sections when linking ELF
files, causing diagnostic tools such as readelf or objdump to
produce partial output. Keep all section at link stage, filter
only at objcopy time so that .bin remains minimal.
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
This change is only done where needed: some linker
scripts may contain relocation symbols yet remain
unchanged.
__rel_dyn_start and __rel_dyn_end each requires
its own output section; putting them in relocation
sections changes their flags and breaks relocation.
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
scripts may contain __image_copy_{start,end} yet
remain unchanged.
Also, __image_copy_end needs its own section; putting
it in relocation sections changes their flags and makes
relocation break.
Discard all .dynsym sections from linker scripts
Remove all __dynsym_start definitions from linker scripts
Remove all __dynsym_start references from the codebase
Note: this touches include/asm-generic/sections.h, which
is not ARM-specific, but actual uses of __dynsym_start
are only in ARM, so this patch can safely go through
the ARM repository.
Commit 3ebd1cbc introduced compiler-generated __bss_start
and __bss_end__ and commit c23561e7 rewrote all __bss_end__
as __bss_end. Their merge caused silent and harmless but
potentially bug-inducing clashes between compiler- and linker-
generated __bss_end symbols.
Make __bss_end and __bss_start compiler-only, and create
__bss_base and __bss_limit for linker-only use.
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Let all ARM linker scripts handle properly -ffunction-sections
and -fdata-sections. This will be useful for future changes in order to create
symbol-specific sections in common .S files.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Turn __bss_start and __bss_end__ from linker-generated
to compiler-generated symbols, causing relocations for
these symbols to change type, from R_ARM_ABS32 to
R_ARM_RELATIVE.
This should have no functional impact, as it affects
references to __bss_start and __bss_end__ only before
relocation, and no such references are done.
This patch modifies start.S for the arm1136 to make it
conform to start.S in armv7 architecture, to make it
usable if the SPL framework is used.
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
Fix checkpatch warning and errors in several i.MX related files.
While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c
regarding the usage of extern in a C file.
setup_weimcs() and some macros are added to support the setup
for i.MX31 WEIM chip selects. As a compromise between verbosity
and readability an ASCII-art'ish bit comment is used instead of
bitfields.
All i.MX31 boards have been patched to use this approach using a
helper program to verify the changes.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Let common code set the machine ID.
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c
Checkpatch.pl complains about the volatile qualifier in calls to
get_ram_size(). Remove this qualifier in the prototype and in the
calls where it is useless, and leave it only in the function body
where it is needed.
This fixes the MX31ADS build by using the new relocation scheme.
Tested-by: Felix Radensky <felix@embedded-sol.com>
Currently, some linker scripts are found by common code in config.mk.
Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is
sometimes in arch config.mk and sometimes in board config.mk. Some
are found using an arch-specific rule for looking in CPUDIR, etc.
Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL
when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact
that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds.
Replace all of this -- except for a handful of boards that are actually
selecting a linker script in a unique way -- with centralized ldscript
finding.
If board code specifies LDSCRIPT, that will be used.
Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used.
If neither of these are specified, then the central config.mk will
check for the existence of the following, in order:
$(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT)
$(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT)
$(TOPDIR)/board/$(BOARDDIR)/u-boot.lds
$(TOPDIR)/$(CPUDIR)/u-boot.lds
Some boards (sc3, cm5200, munices) provided their own u-boot.lds that
were dead code, because they were overridden by a CPUDIR u-boot.lds under
the old powerpc rules. These boards' own u-boot.lds have bitrotted and
no longer work -- these lds files have been removed.
Tested-by: Graeme Russ <graeme.russ@gmail.com>
As exception among the i.MX processors, the i.MX31 has headers
without general names (mx31-regs.h, mx31.h instead of imx-regs.h and
clock.h). This requires several nasty #ifdef in the drivers to
include the correct header. The patch cleans up the driver and
renames the header files as for the other i.MX processors.
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
All in-tree boards that use this controller have CONFIG_NET_MULTI added
Also:
- changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900
- changed CS8900_BASE to CONFIG_CS8900_BASE
- changed CS8900_BUS?? to CONFIG_CS8900_BUS??
- cleaned up line lengths
- modified VCMA9 command function that accesses the device
- removed MAC address initialization from lib_arm/board.c
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
all arm boards except a few use the same cpu linker script
so move it to cpu/$(CPU)
that could be overwrite in following order
SOC
BOARD
via the corresponding config.mk
Signed-off-by: Detlev Zundel <dzu@denx.de>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
