path: root/board/freescale/mx31ads/u-boot.lds
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-13mx31: move freescale's mx31 boards to vendor board dirJean-Christophe PLAGNIOL-VILLARD
