path: root/board/freescale/mx28evk
2014-11-12mx28evk: README: Revision C is also supportedFabio Estevam
Adjust the text to mention that rev C of the board is also supported. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-17mx28evk: Add documentation on how to boot from SPI NORFabio Estevam
Explain the necessary steps in order to boot from SPI NOR. Based on a earlier submission from Mårten Wikman. Signed-off-by: Mårten Wikman <marten.wikman@novia.fi> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-27mx28evk: Propagate the error if cpu_eth_init() failsFabio Estevam
If cpu_eth_init() fails we should return the error immediately. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20mx28evk: Fix checkpatch warningFabio Estevam
Fix the following checkpatch warning: $ ./tools/checkpatch.pl -F board/freescale/mx28evk/mx28evk.c CHECK: Alignment should match open parenthesis #109: FILE: freescale/mx28evk/mx28evk.c:109: + writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN, + &clkctrl_regs->hw_clkctrl_enet); Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-10ARM: mxs: Receive r0 and r1 passed from BootROMMarek Vasut
Make sure value in register r0 and r1 is preserved and passed to the board_init_ll() and mxs_common_spl_init() where it can be processed further. The value in r0 can be configured during the BootStream generation to arbitary value, r1 contains pointer to return value from CALL'd function. This patch also clears the value in r0 before returning to BootROM to make sure the BootROM is not confused by this value. Finally, this patch cleans up some comments in the start.S file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-06-26mx28evk: Move README file inside board directoryFabio Estevam
Board specific READMEs should be located inside the respective board directory. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-05-16mx28evk: Add splash screen supportFabio Estevam
Enable display support. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-28mxs: mmc: Allow overriding default card detect implementationMarek Vasut
Some MXS based boards do not implement the card-detect signal. Allow user to specify alternate card-detect implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: clock: Use 'mxs' prefix for methodsOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-09-24mx28evk: Remove fecmxc_mii_postcall()Fabio Estevam
fecmxc_mii_postcall() is specific to the KSZ9021 PHY on m28evk and should not be used on mx28evk, which has LAN8270 instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-09-04mx28evk: Convert to mxs_adjust_memory_params()Fabio Estevam
Recent conversion from mx28_adjust_memory_params to mxs_adjust_memory_params missed to update mx28evk, which caused the board not to boot. Apply the conversion so that the board can boot again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-09-04MX28: mx28evk: Align SSP clock speedOtavio Salvador
Align the SSP clock speed with oscilator to achieve higher transfer stability. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de>
2012-09-01mxs: Rename 'mx28_dram_init' to 'mxs_dram_init'Otavio Salvador
The DRAM initialization, after SPL has complete, is exactly the same for all mxs SoCs so we should name it accordinly. The following boards has been changed: * apx4devkit * m28evk * mx28evk * sc_sps_1 Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
2012-09-01MX28: Move the u-boot.bd info CPUDIR/SOCDIRMarek Vasut
This gets us rid of duplication of the same file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Reowork SPL to use 'mxs' prefix for methodsOtavio Salvador
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-07-11mx28evk: Add I2C supportFabio Estevam
Add I2C support. Tested by placing a 24LC16 EEPROM into the U50 slot which comes empty from factory. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07mx28evk: Fix boot by adjusting HW_DRAM_CTL29 registerFabio Estevam
commit acc4959fc1 (Revert "i.MX28: Enable additional DRAM address bits") broke mx28evk boot. Fix it by properly adjusting the HW_DRAM_CTL29 register value. Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-05-15mx28evk: add NAND supportLauri Hintsala
NAND support is not enabled by default because Eval Kit is not delivered with NAND chip. To enable NAND support add CONFIG_CMD_NAND to board config. Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Acked-by: Marek Vasut <marex@denx.de>
2012-02-27mx28evk: add SPI supportMatthias Fuchs
This patch adds SPI support for the MX28EVK. Support for an optionally installed SPI flash is also added. An example configuration for redundant envrionment from SPI flash is also added but disabled by default. This patch has been tested on a MX28EVK Rev. D with an installed SST25VF032B 32Mbit SPI flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add USB supportMatthias Fuchs
This patch enables USB host support on the MX28EVK board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-01-16mx28evk: Remove 'all' target from MakefileFabio Estevam
Remove 'all' target from Makefile, as this is unused code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28evk: Add initial support for MX28EVK boardFabio Estevam
Add initial support for Freescale MX28EVK board. Tested boot via SD card and by loading a kernel via TFTP through the FEC interface. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
