path: root/board/freescale/mpc8572ds/law.c
2011-01-14powerpc/85xx: Rework MPC8572DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8572DS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Chenhui Zhao <b26998@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: separate FLASH BASE virtual from physical addressKumar Gala
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: separate PIXIS virtual from physical addressKumar Gala
Added a PIXIS_BASE_PHYS for use as the physical address and maintain PIXIS_BASE as the virtual address of the PIXIS fpga registers. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-29NAND: Add support for MPC8572DS boardHaiying Wang
This patch defines 1M TLB&LAW size for NAND on MPC8572DS, assigns 0xffa00000 for CONFIG_SYS_NAND_BASE and adds other NAND supports in config file. It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image, to make room for the increased code size with NAND enabled. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-27mpc85xx: Add support for the MPC8572DS reference boardKumar Gala
